# Unsure how to install this 3rd party library?
**URL:** <https://forum.inductiveautomation.com/t/unsure-how-to-install-this-3rd-party-library/31369>\
**Tags:** ignition80\
**Created:** [January 17, 2020, 3:49pm UTC](https://forum.inductiveautomation.com/t/unsure-how-to-install-this-3rd-party-library/31369 "2020-01-17T15:49:03Z")\
**Post date:** [January 17, 2020, 3:57pm UTC](https://forum.inductiveautomation.com/t/unsure-how-to-install-this-3rd-party-library/31369/2 "2020-01-17T15:57:45Z")
You can try the procedure documented here:
> [@Procedure for installing python libraries from source](http://forum.inductiveautomation.com/t/procedure-for-installing-python-libraries-from-source/26022/2):
> There’s actually a procedure you can use to use pip from within Jython to install packages, then link Ignition’s Jython lib to an-off-the-shelf Jython lib and use that…however, the article specifically calls out the twilio module as not working, because one of its dependencies, cffi, has C dependencies (IE, won’t work in Jython). For posterity, here’s the procedure, copied verbatim from an internal document: 0) On the server, install Java 8 if you haven’t already. Download the full Jython 2.…
_[View the full topic](https://forum.inductiveautomation.com/t/unsure-how-to-install-this-3rd-party-library/31369)._
