# Use amazon AWS native API
**URL:** <https://forum.inductiveautomation.com/t/use-amazon-aws-native-api/111692>\
**Tags:** scripting\
**Created:** [October 24, 2025, 7:02am UTC](https://forum.inductiveautomation.com/t/use-amazon-aws-native-api/111692 "2025-10-24T07:02:05Z")\
**Showing post:** 6
**Post date:** [October 27, 2025, 3:26pm UTC](https://forum.inductiveautomation.com/t/use-amazon-aws-native-api/111692/6 "2025-10-27T15:26:14Z")
I'm not going to engage with you/your LLM any further than linking these posts where I go through a variety of things that are wrong.
> [@Updating Limble Asset Information through Ignition](https://forum.inductiveautomation.com/t/updating-limble-asset-information-through-ignition/111559/3):
> Your LLM steered you wrong and gave you a lot more code than you need; they're quite good at that. This is less code and does the same as what you wrote, but with better error handling and usable from any scope, not just callable from Perspective. You can drop this into the project library. # ================================ # Limble API credentials # ================================ # These credentials are used to authenticate with the Limble CMMS API. # client\_id and client\_secret are provid…
> [@Ignition Edge sends emails but no attachments](https://forum.inductiveautomation.com/t/ignition-edge-sends-emails-but-no-attachments/111666/9):
> Similar setup here - nothing against you personally, it's just that each time I work through a "person got a mountain of code from an LLM" post and try to guide them through all the things it did wrong makes me feel like Sisyphus. Top level notes: You should only rarely need to import anything in small Ignition scripts. Any imports you do use, you should be judicious about. You should never import system or anything from system. You should never use Jython's datetime library. You should (a…
_[View the full topic](https://forum.inductiveautomation.com/t/use-amazon-aws-native-api/111692)._
