# Using altered dataset from nested query in table group
**URL:** <https://forum.inductiveautomation.com/t/using-altered-dataset-from-nested-query-in-table-group/107127>\
**Created:** [June 6, 2025, 2:20pm UTC](https://forum.inductiveautomation.com/t/using-altered-dataset-from-nested-query-in-table-group/107127 "2025-06-06T14:20:05Z")\
**Post date:** [June 6, 2025, 3:43pm UTC](https://forum.inductiveautomation.com/t/using-altered-dataset-from-nested-query-in-table-group/107127/2 "2025-06-06T15:43:27Z")
You need the techniques in this topic to construct nested query data:
> [@Report with Scripted Nested Data](https://forum.inductiveautomation.com/t/report-with-scripted-nested-data/11801):
> The report datasource scripting examples explain how to access the nested data in another key for use constructing a custom dataset. What I don’t see is how to construct nested data that would be suitable for use with a child table in a table group. I have a parent dataset that I’m constructing via script due to annoying limitations of an ancient SQL Server 2000 instance. I need a subquery for each row that could be done with a normal query, but there’s no way to add a regular subquery to a s…
_[View the full topic](https://forum.inductiveautomation.com/t/using-altered-dataset-from-nested-query-in-table-group/107127)._
