# Using html5/JavaScript component in ignitio
**URL:** <https://forum.inductiveautomation.com/t/using-html5-javascript-component-in-ignitio/19511>\
**Created:** [September 4, 2018, 3:46am UTC](https://forum.inductiveautomation.com/t/using-html5-javascript-component-in-ignitio/19511 "2018-09-04T03:46:02Z")\
**Showing post:** 3
**Author:** ![R.Alamsha](https://avatars.discourse-cdn.com/v4/letter/r/e5b9ba/32.png) [@R.Alamsha](https://forum.inductiveautomation.com/u/R.Alamsha)\
**Post date:** [September 4, 2018, 4:50am UTC](https://forum.inductiveautomation.com/t/using-html5-javascript-component-in-ignitio/19511/3 "2018-09-04T04:50:53Z")
> [@nader.chinichian](#):
> Is possible in import html5/JavaScript component in ignition?
As on date, Ignition client is Java based. We are expecting that they will release a ReactJS client called "Perspective" along with Ignition V8. Until then, you have to build your own JS client. You can check this link.
> [@web-API to read/write tags json](http://forum.inductiveautomation.com/t/web-api-to-read-write-tags-json/19038/36):
> This Ignition project can serve 15,000 dynamic tags from transaction groups as JSON api. You can add 1000’s of tags to the transaction group and serve them as JSON payload. Install SimpleTagProvider-unsigned.modl. (This module is built from Ignition SDK example) This will automatically create 50,000 dynamic tags ignition\_group1.php will serve 1000 dynamic tags as JSON api. To enable unsigned modules in ignition, just add the last line in your ignition.conf. Java Additional Param…
_[View the full topic](https://forum.inductiveautomation.com/t/using-html5-javascript-component-in-ignitio/19511)._
