# Using Ignition to communicate and control an AX350i Domino inkjet printer
**URL:** <https://forum.inductiveautomation.com/t/using-ignition-to-communicate-and-control-an-ax350i-domino-inkjet-printer/88780>\
**Tags:** perspective\
**Created:** [April 13, 2024, 3:42pm UTC](https://forum.inductiveautomation.com/t/using-ignition-to-communicate-and-control-an-ax350i-domino-inkjet-printer/88780 "2024-04-13T15:42:32Z")\
**Post date:** [April 13, 2024, 7:26pm UTC](https://forum.inductiveautomation.com/t/using-ignition-to-communicate-and-control-an-ax350i-domino-inkjet-printer/88780/2 "2024-04-13T19:26:41Z")
This has significantly similar text (cut-and-pasted) from this topic two days ago:
> [@Domino Printer ax350i control from Igniton](https://forum.inductiveautomation.com/t/domino-printer-ax350i-control-from-igniton/88716):
> Does anyone have an example they can share for setting labels on Domino Printers using Codenet commands? I setup the printer in Ignition using the TCP protocol on port 7000, with writeback enabled. Ignition created a few tags on its own when I did this(last received time, message, message bytes, writeable, writeable bytes). I'm assuming I put the commands in the writeable tag, and get feedback in the message tag but I tried entering commands in both ASCII and hex format and didn't see any chang…
Are you the same person?
_[View the full topic](https://forum.inductiveautomation.com/t/using-ignition-to-communicate-and-control-an-ax350i-domino-inkjet-printer/88780)._
