# Using parameter in tag path in an expression
**URL:** <https://forum.inductiveautomation.com/t/using-parameter-in-tag-path-in-an-expression/80126>\
**Created:** [October 6, 2023, 7:09am UTC](https://forum.inductiveautomation.com/t/using-parameter-in-tag-path-in-an-expression/80126 "2023-10-06T07:09:39Z")\
**Showing post:** 9
**Post date:** [October 6, 2023, 7:48am UTC](https://forum.inductiveautomation.com/t/using-parameter-in-tag-path-in-an-expression/80126/9 "2023-10-06T07:48:02Z")
> [@Wiki - how to post code on this forum](https://forum.inductiveautomation.com/t/wiki-how-to-post-code-on-this-forum/77831):
> This thread is intended as a short help file for all those struggling to post formatted code on the forum. Posting formatted code on the forum (and most others) is as simple as selecting the code and pressing the \</\> button. It works the same as applying Bold or Italic styles to your document. It preserves indentation and applies syntax highlighting. [How to post code]
_[View the full topic](https://forum.inductiveautomation.com/t/using-parameter-in-tag-path-in-an-expression/80126)._
