# Vertical Scroll Bar for Container?
**URL:** <https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521>\
**Category:** General Discussion\
**Created:** [April 18, 2016, 8:42am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521 "2016-04-18T08:42:57Z")\
**Posts on this page:** 7\
**Author:** ![ian](https://avatars.discourse-cdn.com/v4/letter/i/bb73d2/32.png) [@ian](https://forum.inductiveautomation.com/u/ian)\
**Post date:** [April 18, 2016, 8:42am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/1 "2016-04-18T08:42:57Z")
I currently am using Container for making Ignition GUI. It is used to contain long lists of signal.
[attachment=0]signal2.png[/attachment]
As the number of signal gets higher, the Container cannot show all of them anymore. Is there any way to have something like Vertical Scroll Bar in Ignition?
**Post date:** [April 18, 2016, 11:55am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/2 "2016-04-18T11:55:39Z")
Use the template repeater or the template canvas. These can display runtime lists or layouts of templates and can have scroll bars.
**Post date:** [April 19, 2016, 2:23am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/3 "2016-04-19T02:23:25Z")
Ah yes, I almost use that. But the thing is, the list contains something else than rather just one time item (not just signal).
If you notice, There is a Close label in the top left of the Container used to close the Container when the user clicks on it. So, the Container contains more than just one template.
I am wondering if there is any solution like Java’s JFrame or WinForm’s/WPF’s StackPanel in Ignition. If there isn’t any, I would also like to know if there is any workaround.
Thanks!
**Post date:** [April 19, 2016, 2:35am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/4 "2016-04-19T02:35:52Z")
I just notice that there is a new component in Ignition 7.8 Template Canvas
[inductiveuniversity.com/video/template-canvas](https://inductiveuniversity.com/video/template-canvas)
Seems like it is especially designed to solve this issue, isn’t it? Will try to figure out the component for a while!
**Post date:** [April 19, 2016, 11:52am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/5 "2016-04-19T11:52:47Z")
Heh. It’s not new, and I suggested it precisely because you weren’t clear on what templates needed to be in the list.
**Author:** ![JGJohnson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jgjohnson/32/29582_2.png) [@JGJohnson](https://forum.inductiveautomation.com/u/JGJohnson)\
**Post date:** [April 19, 2016, 12:47pm UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/6 "2016-04-19T12:47:59Z")
Also you could put the label outside of the template repeater and only show it if the repeater is being shown.
**Post date:** [April 20, 2016, 3:47am UTC](https://forum.inductiveautomation.com/t/vertical-scroll-bar-for-container/11521/7 "2016-04-20T03:47:07Z")
@pturmel: ah yes, I forgot to mention that a Label is in the list (besides the signals). Thanks for the clarification.
@JGJohnson: In the end, I choose to pick that solution. Not exactly what I want since, without work around, it will create boundary between the Close label and the Template Repeater. But that’s fine. What I originally make is a Label with a boundary having Text, “Show” and then as you click on it, the Label is hidden and is replaced with the Container with Label “Close” in the top most - creating the effect of “expanding” rather than “opening”. When I separate the Close Label from the Template Repeater, I would need to create a customized boundary to preserve the “expanding” effect. But yeah, in the end I choose the easier solution.
Thanks all!
