# Vision - closing error box popup via scripting
**URL:** <https://forum.inductiveautomation.com/t/vision-closing-error-box-popup-via-scripting/62902>\
**Tags:** ignition81, vision\
**Created:** [August 11, 2022, 5:24am UTC](https://forum.inductiveautomation.com/t/vision-closing-error-box-popup-via-scripting/62902 "2022-08-11T05:24:44Z")\
**Showing post:** 3
**Post date:** [August 11, 2022, 4:55pm UTC](https://forum.inductiveautomation.com/t/vision-closing-error-box-popup-via-scripting/62902/3 "2022-08-11T16:55:38Z")
You could use the first half of my code here to statically retrieve the error & warning panels:
> [@Getting the Error Messages Dialog Text Through Script](https://forum.inductiveautomation.com/t/getting-the-error-messages-dialog-text-through-script/59983/4):
> from com.inductiveautomation.ignition.client.util.gui import ErrorUtil from org.apache.commons.lang3.reflect import FieldUtils errorPanel = FieldUtils.readStaticField(ErrorUtil, "errorPanel", True) warningPanel = FieldUtils.readStaticField(ErrorUtil, "warningPanel", True) errors = FieldUtils.readField(errorPanel, "errors", True) warnings = FieldUtils.readField(warningPanel, "errors", True) for error in errors: print error.title print error.message print error.exception for warning in warn…
That returns an ErrorPanel, which is a JPanel, so you should be able to walk up from it to the JWindow.
_[View the full topic](https://forum.inductiveautomation.com/t/vision-closing-error-box-popup-via-scripting/62902)._
