# Vision - unable to find what component is causing error
**URL:** <https://forum.inductiveautomation.com/t/vision-unable-to-find-what-component-is-causing-error/90278>\
**Tags:** vision\
**Created:** [May 12, 2024, 2:55pm UTC](https://forum.inductiveautomation.com/t/vision-unable-to-find-what-component-is-causing-error/90278 "2024-05-12T14:55:25Z")\
**Showing post:** 3
**Post date:** [May 12, 2024, 7:54pm UTC](https://forum.inductiveautomation.com/t/vision-unable-to-find-what-component-is-causing-error/90278/3 "2024-05-12T19:54:03Z")
What version of Ignition are you using?
See:
> [@\[IGN-4671\]Random Component Name Error in Vision Client](https://forum.inductiveautomation.com/t/ign-4671-random-component-name-error-in-vision-client/23521/43):
> The workaround I mentioned above will automatically applied by Ignition starting in 8.1.19. Anyone on any older 8.X version should be able to apply it with a client startup script with the same end result.
_[View the full topic](https://forum.inductiveautomation.com/t/vision-unable-to-find-what-component-is-causing-error/90278)._
