# Weather Module
**URL:** <https://forum.inductiveautomation.com/t/weather-module/6166>\
**Category:** 3rd Party Modules\
**Created:** [April 5, 2013, 11:44am UTC](https://forum.inductiveautomation.com/t/weather-module/6166 "2013-04-05T11:44:37Z")\
**Posts on this page:** 3\
**Author:** ![kevinmarchand](https://avatars.discourse-cdn.com/v4/letter/k/439d5e/32.png) [@kevinmarchand](https://forum.inductiveautomation.com/u/kevinmarchand)\
**Post date:** [April 5, 2013, 11:44am UTC](https://forum.inductiveautomation.com/t/weather-module/6166/1 "2013-04-05T11:44:37Z")
Were do you setup the weather module send with the SDK as example?
thanks
**Author:** ![mgross](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/mgross/32/3311_2.png) [@mgross](https://forum.inductiveautomation.com/u/mgross)\
**Post date:** [April 5, 2013, 2:44pm UTC](https://forum.inductiveautomation.com/t/weather-module/6166/2 "2013-04-05T14:44:52Z")
You will need to build the Weather module using Ant. If you unzip the SDK, you will find a WeatherModule inside. You will need to run “ant” on the command line in the WeatherModule/Build folder. This will build the weather .modl file which you can then install in your local Gateway.
**Post date:** [April 5, 2013, 4:13pm UTC](https://forum.inductiveautomation.com/t/weather-module/6166/3 "2013-04-05T16:13:29Z")
Thanks,
I found that you need to create a device to set it up.
