# Why can't custom properties and methods be accessed from a component that is obtained using SwingUtilities.getAncestorOfClass?
**URL:** <https://forum.inductiveautomation.com/t/why-cant-custom-properties-and-methods-be-accessed-from-a-component-that-is-obtained-using-swingutilities-getancestorofclass/78606>\
**Tags:** vision, scripting\
**Created:** [August 31, 2023, 10:07am UTC](https://forum.inductiveautomation.com/t/why-cant-custom-properties-and-methods-be-accessed-from-a-component-that-is-obtained-using-swingutilities-getancestorofclass/78606 "2023-08-31T10:07:05Z")\
**Showing post:** 3
**Post date:** [September 1, 2023, 12:20am UTC](https://forum.inductiveautomation.com/t/why-cant-custom-properties-and-methods-be-accessed-from-a-component-that-is-obtained-using-swingutilities-getancestorofclass/78606/3 "2023-09-01T00:20:03Z")
> [@pturmel](#):
> Custom properties are added to the java standard jython conversion by IA's `PyComponentWrapper`.
Thanks for the hint. Wrapping the swing utility call in the PyComponentWrapper returns the object with the custom properties accessible.
Just for completeness and clarity; the recursive approach always works for returning a component with its custom properties.
**Recursive example to get the parent container of a component:**
```auto
from com.inductiveautomation.factorypmi.application.components import BasicContainer
def getParentContainer(component):
	if isinstance(component.parent, BasicContainer):
		return component.parent
	else:
		parentContainer = getParentContainer(component.parent)
		if parentContainer is not None:
			return parentContainer
parentContainer = getParentContainer(event.source)
The getAncestorOfClass approach returns the expected component and takes far fewer lines of code, but all custom properties are lost:
**Basic SwingUtilities Example:**
```auto
from javax.swing import SwingUtilities
parentContainer = SwingUtilities.getAncestorOfClass(BasicContainer, event.source)
By simply wrapping the swing utility call in a pyComponentWrapper call, the component is returned with the custom properties just like the recursive approach.
**pyComponentWrapper with SwingUtilities example:**
```auto
from com.inductiveautomation.factorypmi.application.script import PyComponentWrapper
parentContainer = PyComponentWrapper(SwingUtilities.getAncestorOfClass(BasicContainer, event.source))
It's only one more line of code, and it's still cleaner looking than building a recursive function.
_[View the full topic](https://forum.inductiveautomation.com/t/why-cant-custom-properties-and-methods-be-accessed-from-a-component-that-is-obtained-using-swingutilities-getancestorofclass/78606)._
