# Why different instances of my component react the same way on different params?
**URL:** <https://forum.inductiveautomation.com/t/why-different-instances-of-my-component-react-the-same-way-on-different-params/75201>\
**Tags:** perspective\
**Created:** [June 19, 2023, 10:01am UTC](https://forum.inductiveautomation.com/t/why-different-instances-of-my-component-react-the-same-way-on-different-params/75201 "2023-06-19T10:01:23Z")\
**Author:** ![victordcq](https://avatars.discourse-cdn.com/v4/letter/v/f6c823/32.png) [@victordcq](https://forum.inductiveautomation.com/u/victordcq)\
**Post date:** [June 19, 2023, 10:56am UTC](https://forum.inductiveautomation.com/t/why-different-instances-of-my-component-react-the-same-way-on-different-params/75201/2 "2023-06-19T10:56:07Z")
this is bugg.
idk if it has been fixed yet if you arent on the lateest patch, try updating if possible since there has been some svg changes not that long ago
else you'll have to change the id for each view
> [@\[BUG-6988\]Embedded View "Template" Instance Behavior](https://forum.inductiveautomation.com/t/bug-6988-embedded-view-template-instance-behavior/68170/13):
> To get an SVG to work in the current version, you need to not have duplicate svgs where their definition contains any reference to a hard-coded id and your goal is to change their color. Any svg which contains color definitons inside of the svg in a manner like this: style="fill: url("#s0\_3-SVGID\_1\_");" will result in this issue because they're defining their appearance (fill, in this case) based off of a specific id present in the DOM. When they search for that id, they will always find the fi…
_[View the full topic](https://forum.inductiveautomation.com/t/why-different-instances-of-my-component-react-the-same-way-on-different-params/75201)._
