# Write message in log
**URL:** <https://forum.inductiveautomation.com/t/write-message-in-log/62908>\
**Created:** [August 11, 2022, 7:38am UTC](https://forum.inductiveautomation.com/t/write-message-in-log/62908 "2022-08-11T07:38:46Z")\
**Showing post:** 3
**Post date:** [August 11, 2022, 4:39pm UTC](https://forum.inductiveautomation.com/t/write-message-in-log/62908/3 "2022-08-11T16:39:21Z")
And this one:
> [@Event Configuration Print Out to debug](https://forum.inductiveautomation.com/t/event-configuration-print-out-to-debug/60091/5):
> It’s complicated slight_smile Starting from most local to least… In the script console, print will log directly to the output buffer on the right hand side. system.util.getLogger() will log to the named ‘Output Console’ Designer window. Bonus: A script invoked from here using system.util.invokeAsync will print to the regular output console, not the buffer on the right hand side. Anywhere else in the designer (except Perspective), print and system.util.getLogger will log to the ‘Out…
_[View the full topic](https://forum.inductiveautomation.com/t/write-message-in-log/62908)._
