# XYChart backgroundColor not changing with Theme
**URL:** <https://forum.inductiveautomation.com/t/xychart-backgroundcolor-not-changing-with-theme/56412>\
**Created:** [February 22, 2022, 3:18pm UTC](https://forum.inductiveautomation.com/t/xychart-backgroundcolor-not-changing-with-theme/56412 "2022-02-22T15:18:29Z")\
**Post date:** [February 22, 2022, 3:40pm UTC](https://forum.inductiveautomation.com/t/xychart-backgroundcolor-not-changing-with-theme/56412/2 "2022-02-22T15:40:47Z")
You’re setting the wrong property. You should be setting
`props.background.color`
and you’ll need to set
`props.background.render : color`.
The chart components don’t understand Ignition’s CSS themes so you can’t use the `var(--neutral-00)` syntax. As a workaround I’ve created an expression binding on the background color as follows:
```auto
if(
	left({session.props.theme}, 4) = 'dark',
	'#aaaaaa',
	'#222222'
Note that this relies on all your dark themes starting with the letters `dark`.
A better way would be:
1. Create a session custom variable `chartBackgroundColor`.
2. Bind that to `session.props.theme` using the code above.
3. Bind your charts `props.background.color` to `session.custom.chartBackgroundColor’.
Now you’ll be able to update all the charts’ backgrounds in one place. (To make it more obvious to the next guy you could create two session variables, `chartBackgroundColorDark : #aaaaaa`, etc. and reference those in the binding.
_[View the full topic](https://forum.inductiveautomation.com/t/xychart-backgroundcolor-not-changing-with-theme/56412)._
