Acknowledge button for touchscreen
I want to use the Alarm status Table object in a touchscreen project however the acknowledge button is far too small. I am having difficulty getting a script on a separate larger button for this purpose to work. I have looked at the system.alarm.acknowledge method but am having difficulty getting the selected alarm EventId to pass to the button script. Can you help please . I am using version 7.6
Alan
Try this to change the size of the button.
[code]from java.awt import Dimension
alarmStatus = event.source.parent.getComponent(‘Alarm Status Table’)
ackButton = alarmStatus.getComponents()[0].getComponents()[1].getComponents()[0].getComponents()[0]
dim = Dimension(200,50)
ackButton.setSize(dim)
ackButton.setPreferredSize(dim)[/code]
Figured this out for myself eventually.
Created new button and hid button on the Alarm Status Table. Set Alarm Status Table to only allow one row selection.
Script on button
results = even.source.parent.getComponent(‘Alarm Status Table’).selectedAlarms
uuid = [str(results.getValueAt(0,‘EventId’))]
system.alarm.acknowledge(uuid, “none”)
enabled binding on the button
if ({Root Container.Alarms.Low_Pri_Alarms.Alarm Status Table.selectedAlarms) = none,0,1) to prevent erro when button pushed when no alarm is selected
Did you try what jpark suggested?
