Apparently, Ignition decided that I need “UPDATE Query” enabled on all UI fields that use an SQL binding (I’ve seen it on text fields, dropdown lists and checkboxes).
Whenever I add a new GUI item, and define a query binding to some parameter, the “UPDATE Query” is enabled by default (this used to be disabled by default). However, it can be seemingly disabled in the designer. But whatever you do, it will spit errors in the client because the query isn’t valid. And the next time you open the designer, everything is enabled again.
Has someone else seen this? We’re using version 7.9.7, on an Ubuntu server on OpenJDK 1.8.0_162. This has happened on two servers with different projects, but an almost identical configuration.
The projects are upgraded from older 7.9 versions though, before the named queries appeared. Luckily, there’s no table with the name “tablename”, so all those queries just fail, and I can update the DB with one click on the “submit” button.
Now I’m getting nullpointer exceptions when editing the query to get the dropdown selection list.
Note that this is a different query, the original problems were related to the “selected value” update query, but this is related to the “data” field of the dropdown.
Although another dropdown now throws a nullpointer when trying to change the “selected value” query. Sigh
At this point, the only way out I’ve found is copy-pasting the object to a text editor, editing the query there, and copy-pasting it back again.
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.binding.SQLPropertyAdapter.getBindingConfiguration(SQLPropertyAdapter.java:117)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.getBindingConfiguration(ConfiguratorMultiplexor.java:284)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.tryCommit(ConfiguratorMultiplexor.java:266)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor.tryCommit(ConfiguratorMultiplexor.java:468)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.doOK(DynamicOptsDialog.java:95)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.access$000(DynamicOptsDialog.java:43)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog$1.actionPerformed(DynamicOptsDialog.java:64)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:163)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:1125)
at com.inductiveautomation.factorypmi.designer.property.editors.bb.DynamicOptionsButton.actionPerformed(DynamicOptionsButton.java:37)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI$Handler.repostEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(Unknown Source)
at com.jidesoft.swing.DelegateMouseInputListener.mouseReleased(Unknown Source)
Also tried to move to named queries now, and that works ... partially. At least I don't get null pointers when trying to update queries, and the "Update query" checkbox can be disabled now.
But there are still quite a lot of strange things happening, like the bindings replacing themselves when you publish the window. However, that is only noticeable when you alter the binding again, as long as you don't alter it, it seems to use the correct binding in the client.
Before attempting to downgrade, make sure that you have a Gateway Backup that was taken from the version you want to downgrade to or an older version.
So we can only restore versions that were developed on 7.9.6 or older.
Given that we first started working on the PLC side, preparing the actual SCADA, and only recently started on the the database side. It would be quite costly to downgrade. And given that the issue didn't really come up until publishing these windows again, it was very hard for us to notice on beforehand.
I'm also missing some communication from IA. Where can I find it's a known bug? Where can I find when a fix is estimated to arrive? Do we need to spend a week backporting it to 7.9.6? I follow their blogs and the forums quite closely, I often check the documentation, yet I can't seem to find any info on this problem.
To me, this is a major bug, and IA should probably warn anyone trying to install 7.9.7 that the vision SQL bindings have issues.
I just tested on the final version of 7.9.8 (which should be out within a few weeks) and can confirm that I did not have the issue with the update query being pre-selected/unable to be ignored.
I am having this problem in version 7.9.8 with a display label. The update query checkbox always checks itself or will throw an exception because the default table it creates doesn’t exist, whenever I launch a client or run the designer in preview mode. The only work around I have found is by changing it to a named query.
Any bindings corrupted by this bug (by editing the binding in an affected version) remain corrupted in 7.9.8. The fix prevents further corruption, but cannot get rid of existing corruption. In v7.9.8, delete the corrupt binding, accept it, then make a new binding.
There’s still an issue with the update query checkbox in 7.9.8 (already fixed in 7.9.9). To get around it, just empty the ‘Update Query’ field of text entirely before saving any modifications to those bindings. You’ll unfortunately have to do this every time you modify the binding.
I indeed was a bit too early to call it solved, it works on the initial edit, but later on, the problem reoccured.
Yes, but sadly, if you edit it a second time, the update query gets activated again, and you need to close and reopen the window in the designer to be able to clear it again. Very convoluted to keep a project error-free this way ...
