I have a very small table, 4 rows, with 3 columns, step number, instruction for that step, and a status column. What I ideally want is that for the current step in the process to be a certain color, yellow, any previously completed steps to be green, any future step to be default. I tried looking into the extension function thinking I could just do if this current row is selected, make it yellow, if the row number is < selectedRow, make it green and I’d be done, but I see there is no tag/property button on the top right of the script editor as there usually is. How can I go about making this work?
So I am completely clear, on open -
Row 1 - yellow
Row 2 - default
Row 3 - default
Row 4 - default
User completes step 1
Row 1 - Green
Row 2 - Yellow
Row 3 - Default
Row 4 - Default
User completes step 2
Row 1 - Green
Row 2 - Green
Row 3 - Yellow
Row 4 - Default
and so on. How can I accomplish this? I have a root container variable that keeps track of what step in the process I am currently on and will only increment when the current step is complete.
Edit - per this post Change row color of table dynamically
I found a decent way to make a single column the correct color, how do I apply a single columns background color via mapping apply to the entire row? Then I will be set.
