i am working on a simple bar chart and i would like to color the bars based on several target values.
Following example:
As you can see i would like to import machine based target values into the barchart, so the formatting can be made by these values. It’s possible for me to provide the target values as a dataset (Machine || target) in Ignition, but i am not shure how to use them in the scripting.
I’m very new into developing Ingition applications, so i hope someone can help me out
You can set the colors of the series from a script like this:
from java.awt import Color
event.source.parent.getComponent('Bar Chart').seriesColors = [Color.decode("#00FFFF"), Color.decode("#FF00FF")]
I don’t know how to set the color on individual bars though
But perhaps you can hack your way around by having a “good” and “bad” series in your dataset and using stacked bars. Then you don’t even need dynamic colors, but you do need a script to write data to the “good” or “bad” column depending on the values.
@Sanderd17
Thank you for your help
It was possible to solve the problem by using a staked bar chart wird “good/bad” values (in the SQL Statement) for the same measure. Now it is possible for me to show some nice prepared values
On the BarChart component, put the following in the getBarColor extension function.
data = self.data
categoryName = data.getValueAt(category,"Label")
red = Color.RED
green = Color(113,174,70)
if categoryName == "M1":
if value < 6:
return red
else:
return green
elif categoryName == "M2":
if value < 7:
return red
else:
return green
elif categoryName == "M3":
if value < 3:
return red
else:
return green
elif categoryName == "M4":
if value < 4:
return red
else:
return green
return defaultColor
