I have a view which contains a numeric entry component and a label. The view has a parameter tagPath
, and the value of my numeric entry component uses indirect tag binding to {tagPath}
(which is the reference for {view.params.tagPath}
). The binding is bi-directional.
If I enter a valid path into the view tagPath parameter and test the display, I can read and write the value.
Now, I embed that view into another view, and pass the same tag path into its tagPath parameter. When I test the display, the value updates correctly but I cannot write to the tag.
Should this be possible, or do I need to try a different approach? The embedded view is clearly receiving the correct tag path, as it’s displaying and updating the correct tag value, so I can’t see why it would not be bi-directional as that part of the binding can’t be programmatically changed.
