After restoring a 7.9 gateway backup, the Ignition 8 gateway fails to start. The gateway homepage shows the spinning ‘Starting’ wheel and the log ends with the entrys posted here.
The backup is from a 7.9 gateway on windows and imported to yesterdays nightly build on a linux vm.
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up...
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.alarm-notification' v5.0.0-beta0 (b2019030902)... module-name=Alarm Notification
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.taghistorian' v3.0.0-beta0 (b2019030902)... module-name=Tag Historian
INFO | jvm 2 | 2019/03/12 17:24:13 | I [h.ModuleHook ] [16:24:13]: Tag Historian module started. module-name=Tag Historian
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.vision' v10.0.0-beta0 (b2019030902)... module-name=Vision
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.opcua' v8.0.0-beta0 (b2019030902)... module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://vm-ignition-8:4096 to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://vm-ignition-8:4096 to 0.0.0.0:4096 [Basic128Rsa15/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://vm-ignition-8:4096 to 0.0.0.0:4096 [Basic256Sha256/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://vm-ignition-8:4096/discovery to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://localhost:4096 to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://localhost:4096 to 0.0.0.0:4096 [Basic128Rsa15/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://localhost:4096 to 0.0.0.0:4096 [Basic256Sha256/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://localhost:4096/discovery to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://127.0.0.1:4096 to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://127.0.0.1:4096 to 0.0.0.0:4096 [Basic128Rsa15/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://127.0.0.1:4096 to 0.0.0.0:4096 [Basic256Sha256/SignAndEncrypt] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [o.e.m.o.s.s.UaStackServer ] [16:24:13]: Binding endpoint opc.tcp://127.0.0.1:4096/discovery to 0.0.0.0:4096 [None/None] module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [OpcUaModule ] [16:24:13]: Routes mounted module-name=OPC-UA
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.sqlbridge' v9.0.0-beta0 (b2019030902)... module-name=SQL Bridge
INFO | jvm 2 | 2019/03/12 17:24:13 | I [s.ProjectRunner ] [16:24:13]: Project started. module-name=SQL Bridge, project-name=TestReport
INFO | jvm 2 | 2019/03/12 17:24:13 | I [s.ProjectRunner ] [16:24:13]: Project started. module-name=SQL Bridge, project-name=global
INFO | jvm 2 | 2019/03/12 17:24:13 | I [s.ProjectRunner ] [16:24:13]: Project started. module-name=SQL Bridge, project-name=MES_Test
INFO | jvm 2 | 2019/03/12 17:24:13 | I [g.ModuleManager ] [16:24:13]: Starting up module 'com.inductiveautomation.reporting' v5.0.0-beta0 (b2019030902)... module-name=Reporting
INFO | jvm 2 | 2019/03/12 17:24:14 | Fontconfig error: Cannot load default config file
INFO | jvm 2 | 2019/03/12 17:24:14 | java.lang.ClassCastException: class sun.font.CompositeFont cannot be cast to class sun.font.PhysicalFont (sun.font.CompositeFont and sun.font.PhysicalFont are in module java.desktop of loader 'bootstrap')
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.font.SunFontManager.getDefaultPhysicalFont(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.font.SunFontManager.initialiseDeferredFont(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.font.SunFontManager.initialiseDeferredFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.font.SunFontManager.loadFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.awt.X11FontManager.loadFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.font.SunFontManager.getAllInstalledFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.java2d.SunGraphicsEnvironment.getAllFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.desktop/sun.java2d.HeadlessGraphicsEnvironment.getAllFonts(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFontUtils.getFonts(RMFontUtils.java:51)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFontUtils.guessFont(RMFontUtils.java:146)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFontUtils.getFont(RMFontUtils.java:43)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFontFile.<init>(RMFontFile.java:64)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFontFile.getFontFile(RMFontFile.java:48)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFont.<init>(RMFont.java:75)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFont.<clinit>(RMFont.java:42)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.shape.RMDocument.<init>(RMDocument.java:81)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.common.resource.ReportResource.<init>(ReportResource.java:28)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.lang.Class.newInstance(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.startSubElement(ObjectDeserializationHandler.java:101)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:850)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:151)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:239)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:171)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.gateway.scheduler.ReportScheduleRunner.addSchedulesFromResource(ReportScheduleRunner.java:88)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.gateway.scheduler.ReportScheduleRunner.startup(ReportScheduleRunner.java:78)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.gateway.scheduler.ReportScheduleRunner.startup(ReportScheduleRunner.java:62)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$ReportingProjectLifecycle.onStartup(ReportingGatewayHook.java:556)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycle.onStartup(ProjectLifecycle.java:38)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.lifecycle.AbstractLifecycle.startup(AbstractLifecycle.java:18)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.maybeStartLifecycle(ProjectLifecycleFactory.java:239)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.projectAdded(ProjectLifecycleFactory.java:125)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.ArrayList.forEach(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory.onStartup(ProjectLifecycleFactory.java:43)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.reporting.gateway.ReportingGatewayHook.startup(ReportingGatewayHook.java:160)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:2349)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startup(ModuleManagerImpl.java:396)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1116)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:275)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:664)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:602)
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:14 | E [C.BasicExecutionEngine ] [16:24:14]: One-shot task com.inductiveautomation.ignition.gateway.IgnitionGateway$$Lambda$240/0x000000010034d040@40ae2376 threw uncaught exception. module-name=Reporting
INFO | jvm 2 | 2019/03/12 17:24:14 | java.lang.ExceptionInInitializerError: null
INFO | jvm 2 | 2019/03/12 17:24:14 | Caused by: java.lang.RuntimeException: java.lang.ClassCastException: class sun.font.CompositeFont cannot be cast to class sun.font.PhysicalFont (sun.font.CompositeFont and sun.font.PhysicalFont are in module java.desktop of loader 'bootstrap')
INFO | jvm 2 | 2019/03/12 17:24:14 | at com.inductiveautomation.rm.text.RMFont.<clinit>(RMFont.java:50)
INFO | jvm 2 | 2019/03/12 17:24:14 | ... 42 common frames omitted
INFO | jvm 2 | 2019/03/12 17:24:14 | Caused by: java.lang.ClassCastException: class sun.font.CompositeFont cannot be cast to class sun.font.PhysicalFont (sun.font.CompositeFont and sun.font.PhysicalFont are in module java.desktop of loader 'bootstrap')
INFO | jvm 2 | 2019/03/12 17:24:14 | I [o.e.m.o.s.c.OpcUaClient ] [16:24:14]: Eclipse Milo OPC UA Stack version: 0.3.0-SNAPSHOT
INFO | jvm 2 | 2019/03/12 17:24:14 | I [o.e.m.o.s.c.OpcUaClient ] [16:24:14]: Eclipse Milo OPC UA Client SDK version: 0.3.0-SNAPSHOT
INFO | jvm 2 | 2019/03/12 17:24:14 | I [o.e.m.o.s.c.u.NonceUtil ] [16:24:14]: SecureRandom seeded in 0ms.
INFO | jvm 2 | 2019/03/12 17:24:15 | E [LegacyScripting[system_util_tag]] [16:24:15]: Error writing tags
INFO | jvm 2 | 2019/03/12 17:24:15 | Error writing to tag 'ForcamDACQNutzen': Error_Configuration("Tag provider '' not found")
INFO | jvm 2 | 2019/03/12 17:24:20 | E [t.e.a.history ] [16:24:19]: Error storing tag history data store-forward-name=prozessdaten
INFO | jvm 2 | 2019/03/12 17:24:20 | java.lang.IllegalArgumentException: Specified historical sink 'prozessdaten' does not exist.
INFO | jvm 2 | 2019/03/12 17:24:20 | at com.inductiveautomation.ignition.gateway.history.HistoryManagerImpl.storeHistory(HistoryManagerImpl.java:166)
INFO | jvm 2 | 2019/03/12 17:24:20 | at com.inductiveautomation.gateway.tags.history.actor.HistoryActorFactory$DelayedEvaluationContainer.process(HistoryActorFactory.java:774)
INFO | jvm 2 | 2019/03/12 17:24:20 | at com.inductiveautomation.gateway.tags.history.actor.HistoryActorFactory$DelayedEvaluationContainer.run(HistoryActorFactory.java:749)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 2 | 2019/03/12 17:24:20 | at java.base/java.lang.Thread.run(Unknown Source)
