Bug? Dropdown boxes populated from a database
I encountered a problem populating my dropdown boxes from my database. I created a dropdown box and gave it this query:
SELECT pmkSupplier, supplierName
FROM supplier
ORDER BY supplierName ASC
Works great.
If I copy/paste (drag+ctrl) the dropdown box, then I have two dropdowns returning the same thing. Also good.
However, if I try to edit the SQL in either dropdown box, after I click OK I receive the error (at the end of the post), and the change doesn’t stick:
This only seems to happen if I create a copy of the input. Creating a new one works fine.
I’m using ignition 7.9.7 and this is the second SQL related error I’ve run into with this version. Thoughts?
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
	at com.inductiveautomation.factorypmi.application.binding.SQLPropertyAdapter.getBindingConfiguration(SQLPropertyAdapter.java:117)
	at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.getBindingConfiguration(ConfiguratorMultiplexor.java:284)
	at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.tryCommit(ConfiguratorMultiplexor.java:266)
	at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor.tryCommit(ConfiguratorMultiplexor.java:468)
	at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.doOK(DynamicOptsDialog.java:95)
	at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.access$000(DynamicOptsDialog.java:43)
	at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog$1.actionPerformed(DynamicOptsDialog.java:64)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
	at java.awt.WaitDispatchSupport$2.run(Unknown Source)
	at java.awt.WaitDispatchSupport$4.run(Unknown Source)
	at java.awt.WaitDispatchSupport.enter(Unknown Source)
	at java.awt.Dialog.show(Unknown Source)
	at java.awt.Component.show(Unknown Source)
	at java.awt.Component.setVisible(Unknown Source)
	at java.awt.Window.setVisible(Unknown Source)
	at java.awt.Dialog.setVisible(Unknown Source)
	at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:163)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:1125)
	at com.inductiveautomation.factorypmi.designer.beaninfo.PMIComboBoxBeanInfo$1.onDoubleClick(PMIComboBoxBeanInfo.java:140)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.handleDoubleClick(WindowWorkspace.java:817)
	at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.onDoubleClick(SelectionTool.java:553)
	at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:984)
	at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:72)
	at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
The presences of dialog.setVisible() and dialog.show() way up in the call chain suggests this is a bug.
This is a regression in 7.9.7 that’s already fixed for 7.9.8.
