[Bug] View Not Opening - sqlite database locked
Version: 8.0.0-beta0 (b2019030502)
I’m not sure what logs it wants me to look at, but I’m not seeing anything in the wrapper logs nor the gateway logs. Not sure if I need to adjust filters to see what error it is giving.
In the console, I see the following messages:
13:17:31.158 [Designer-Startup] INFO Perspective.Designer - Starting up Perspective module. Mode: Activated
01:17:31 SEVERE: [0305/131731.172:ERROR:connection.cc(1862)] History sqlite error 5, errno 33: database is locked, sql: COMMIT
01:17:31 SEVERE: [0305/131731.174:ERROR:connection.cc(1862)] Passwords sqlite error 5, errno 33: database is locked, sql: PRAGMA auto_vacuum
01:17:31 SEVERE: [0305/131731.178:ERROR:connection.cc(1862)] Passwords sqlite error 5, errno 33: database is locked, sql: PRAGMA journal_mode = TRUNCATE
01:17:31 SEVERE: [0305/131731.207:FATAL:material_design_controller.cc(169)] Check failed: is_mode_initialized_.
13:19:31.185 [Designer-Startup] ERROR designer.JXBrowserUtil - Failed to initialize JxBrowser
A post was merged into an existing topic: [Bug-12976]Build 8.0.0-beta0 (b2019030402):Error uninstalling, installing or restarting custom module
