Button - Primary & Secondary Style
I saw a post from back in April 2019 about button Primary and Secondary state style (where the color changes based on if the button is pressed or not), it read that the only way to change the primary style (which is currently blue) is to go into the Ignition program files:
I was just wondering if that was still the only way to change the primary button style as I cannot seem to find any other way to do so without completely coloring a button, which makes it so it is always one color regardless of if it is pressed or not.
Yes, the theme files are where you would want to make Perspective-wide changes to the colors/styling of any Perspective component.
