Requirement: Ignition V 7.6.0 or greater
This module is FREE
A simple DRIVER PING MODULE to check the communication with ethernet equipement with ping requests.
Configure with an IP address range or a list
According to the number of equipement, increase the number of threads.
Here is the new module for Ignition 8.0.12+
You can create ping, snmp v1, v2c, v3 and trap listener devices.
you can read/write simple oid and read oid table.
I will perhaps release this modules.
Hi
I have created a Byes Ping device and I was expecting to see fields to enter IP address and range but all I have is as per image below. Am I missing something? Version 8.0.16
In this new version of the ping driver, you can create one device, for example [PingDevice].
Then you create opc tag with opcItemPath for each equipement you want to ping:
Is this module still available? I would like to try it with version 8.1.2 if possible but the Dropbox file is deleted. I thought about trying the older versions posted but wanted to check first. Thanks!
