I can't seem to figure out how to capture a Jython Exception in a try...except.
I have tried this format and it works for capturing database exceptions.
import java.lang.Exception
try:
# something something something
except Exception, e:
# jython exception
except java.lang.Exception, e:
# java exception
I have never been able to capture a JythonExecException. Like a divide by zero, or an exception with Sepasoft API, or an invalid reference or datatype passed into a function.
Is it possible? I am using Ignition v8.0.13.
I’m on 7.9 but I would assume it would be the same for 8.0. I have a number of shared functions that I call from gateway timer events. To capture any errors they get I use something like:
import traceback
import sys
def test():
x = 1/0
return x
try:
test()
except Exception, err:
exc_type, exc_value, exc_tb = sys.exc_info()
errtb = traceback.format_exception(exc_type, exc_value, exc_tb)
errStr = str("This Script returned an error: "+str(err)+errtb[1] + errtb[2])
# logger = system.util.getLogger("testScript")
# logger.info(errStr)
print errStr
I commented out the logger part of it and used print to show you want it returns in the logs. I’m not sure if this is exactly what your looking for but its what I use for capturing exceptions in functions.
@bpreston thanks for your response, I figured out my issue.
I was doing this:
try:
h = 1/0
# handle jython exceptions
# Log the error.
msg = e.getCause().getMessage() # <<--- this was causing another exception
# handle java exceptions
# Log the error.
I ended up doing this and I was able to capture the exception:
try:
h = 1/0
# Log the error.
msg = str(e)
# Log the error.
It just dawned on me that the Jython exception object is different that the java exception object. I was referencing a method that did not exist. It helps when I carefully read the exception in the log, it was trying to tell me. I also did not provide that detail in my original post, my bad.
@bpreston I like how you generated the error string for the Jython exception, I plan to use that. Thanks again.
Just a follow up to my original post…
I added a check for e.getClause() in the exception handler for java exceptions, because if the exception caught was not chained (an exception thrown by another exception) and you call “e.getCause().getMessage()” this will throw another exception. Here’s my latest implementation for capturing exceptions.
import sys
import traceback
try:
h = 1/0
msg = str(str(e)+ errtb[1] + errtb[2])
#do something
# Log the error.
if e.getCause():
message = e.getCause().getMessage()
else:
message = str(e)
#do something
I hope this helps others!
For further edification, this forum has numerous discussions of these behaviors:
http://forum.inductiveautomation.com/search?q=except%20java.lang.Exception
You might find the PythonAsJavaException class from later.py handy if you need to include a python exception in a chain of exception causes, or want to include a complete java backtrace with causes when reporting a python exception.
