Change color of one point in a XYChart
Hi All,
I want to change the color of some point inside a Chart component. I tried myself but I’m not so familiar with Java ( yet :wink: ).
After a lot of Googleing around I know I have to determine which renderer class is being used ( org.jfree.chart.renderer.xy.StandardXYItemRenderer ) and create a subclass of it where override the getItemPaint() method to return a specific color for the data item that I wish to highlight, but I don’t know how to do it :sweat_smile:
Any help would be much much appreciated :slight_smile:
Cheers,
Nobody? :disappointed_relieved:
Something like this should do the trick.
	from org.jfree.chart.renderer.xy import StandardXYItemRenderer
	from java.awt import Color
	class myXYItemRenderer(StandardXYItemRenderer):
		def getItemPaint(self,row,column):
			#whatever criteria you want to use to determine color
			if row == 0 and column >= 12:
				return Color.BLACK
			else:
				return StandardXYItemRenderer.getItemPaint(self,row,column)
	chart.getXYPlot().setRenderer(myXYItemRenderer())
Thanks!! :+1::+1:
For posterity:
row is the series
column is the item
