hi everyone i would like to know if there is any way to change a string or int variable to time, I currently have something like this
Contador = system.tag.read(dateFormat(addSeconds(midnight(now()),"[.]MemTimeDiff","HH:mm:ss"))
You’re mixing Jython and the expression language here. Where are you trying to use this? Also, either way, the conversion from string to time would need to be applied to the tag value, rather than trying to read the value of the the string to time conversion as your code above does.
I want it to save the data in a database
if currentValue.value == False and currentValue.value != previousValue.value and not initialChange:
INS = "INSERT INTO PAROS ( Linea, Maquina, TipoParo, TiempoParo, Fecha) VALUES ( ?, ?, ?, ?, ?)"
Fecha = system.date.now()
system.db.runPrepUpdate(INS,[ "Item", "Prueba", "Prueba", Contador.value, Fecha],"TOY")
dateFormat(addSeconds(midnight(now([.]MemTimeDiff with the full path to the tag–something like the example in the next point. EDIT: You actually can use this here, as others have pointed out.
.value before trying to manipulate it:system.tag.read("[default]MemTimeDiff").value
system.tag.read as in your example. You’ll end up with something like the following (untested).timeDiff = system.tag.read("[default]MemTimeDiff").value
Contador = system.date.format(system.date.addSeconds(system.date.midnight(system.date.now()), timeDiff), "HH:mm:ss")
@witman this topic will help at least clarify the relative tagpath (tl;dr It’s a tag event script)
You actually can use relative paths in Jython
for example in a tag change script
I get an error back
([default]CONTEO DE FALLA/Falla safety fance open 1, valueChanged) Error executing tag event script: Traceback (most recent call last): File "tagevent:valueChanged", line 6, in valueChanged AttributeError: 'com.inductiveautomation.ignition.common.script.Imm' object has no attribute 'data'
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 6, in valueChanged AttributeError: 'com.inductiveautomation.ignition.common.script.Imm' object has no attribute 'data'
at org.python.core.Py.AttributeError(Py.java:173)
at org.python.core.PyObject.noAttributeError(PyObject.java:930)
at org.python.core.PyObject.getattr(PyObject.java:925)
at org.python.pycode._pyx97434703.valueChanged$1(:9)
at org.python.pycode._pyx97434703.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.call(PyFunction.java:371)
at org.python.core.PyFunction.call(PyFunction.java:361)
at org.python.core.PyFunction.call(PyFunction.java:356)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:649)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$FunctionInvokerImpl.run(TagScriptManager.java:493)
at com.inductiveautomation.ignition.common.sqltags.scripts.AbstractTagScript.invoke(AbstractTagScript.java:33)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$Task.invoke(TagScriptManager.java:442)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.run(TagScriptManager.java:405)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 6, in valueChanged AttributeError: 'com.inductiveautomation.ignition.common.script.Imm' object has no attribute 'data'
... 24 common frames omitted
this is the code
INS = "INSERT INTO PAROS (Linea, Maquina, TipoParo, TiempoParo, Fecha) VALUES (?, ?, ?, ?, ?)"
timeDiff = system.tag.read("[.]MemTimeDiff").value
Contador = system.date.format(system.date.addSeconds(system.date.midnight(system.data.now()), timeDiff), "HH:mm:ss")
system.db.runPrepUpdate(INS,["Item","Prueba","Prueba",Contador.value,Fecha],"TOPY_MW")
You have a typo in your code.
You have data when you should have date
TypeError: addSeconds(): 2nd arg can't be coerced
to int
It doesn't like timeDiff, is that tag of type string? You can make the timeDiff tag of type int or maybe use
int(system.tag.read("[.]MemTimeDiff").value)
is already saving time.
only instead of saving 40 min. save me 40 seconds.
timeDiff = int(system.tag.read("[.]../MemTimeDiff").value)
system.db.runPrepUpdate(INS,["Item","Prueba","Prueba",Contador,Fecha],"TOPY_MW")
Is [.]../MemTimeDiff minutes? If so, you need to add minutes, not seconds:
Contador = system.date.format(system.date.addMinutes(system.date.midnight(system.date.now()), timeDiff), "HH:mm:ss")
