I try to read sql tags in the client context of a module and I have the following error :
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to locate function ‘SQLTags.read’
clientContext is memorized from the startup AbstractClientModuleHook.
The exposed function is used in a client script :
import system
liste = []
liste.append("testAlarme")
system.byes.utils.readTag("default",None,liste)    @ScriptFunction(docBundlePrefix = "ClientScriptModule")
    public void readTag(
            @ScriptArg("source") String source,
            @ScriptArg("system") String system,
            @ScriptArg("pathParts") java.util.List<java.lang.String> pathParts) {
        try {
            List<TagPath> paths = new ArrayList<TagPath>();
            TagProp prop = TagProp.Value;
            paths.add(new BasicTagPath(source,system,pathParts,prop));
            java.util.List<QualifiedValue> qv = this.clientContext.getTagManager().read(paths);
            // une seule valeur prévue pour ce test
            logger.info("readTag return V : " + qv.get(0).getValue().toString());
            logger.info("readTag return T : " + qv.get(0).getTimestamp().toString());
            logger.info("readTag return Q : " + qv.get(0).getQuality().toString());
        } catch (Exception e) {
            logger.error(e.getMessage());
    }I don’t understand what I have missed
