CMMS and Ignition
Hi All,
I was just wondering if anyone on here could recommend CMMS packages that they have had good experience with. Trying to vet out different options and ultimately would like to have a CMMS system that integrates well with Ignition. I tend to use MySQL for my Ignition databases. Not sure if that would make a difference on the CMMS selection.
Thanks in advance for any feedback,
-Will
You could make your own CMMS with Ignition.
Thanks Nick! Yeah I’ve thought about that. At the moment I don’t have the time to put in all of the features that we are looking for in a CMMS solution (I work on Ignition part time). I was hoping that there might be some CMMS packages out there that others have had good experience with.
If anyone has any good 3rd party CMMS recommendations, I would appreciate any feedback.
Thanks,
-Will
We use a stand alone system called Express Maintenance. It has worked well over the years.
expresstechnology.com/mainte … aintenance
WillMT10, did you ever move forward with anything on this?
I realize this is a very old post but I am now in the same position looking to find something that integrates with ignition.
Thanks for any information.
Mark
The Ops team ended up moving forward with Maintenance Connection. Personally, I would not recommend going this route. Not very user friendly. I know the team wants to switch to a new solution once our contract is up for renewal.
Hi @Mark.Davis,
I was planning to build one form scratch based on perspective and upload it to the exchange. But this will not be before second quarter of 2024 since there is a lot of work to do.
But i more than happy to listen to your needs and try to fit to this resource.
Regards
Arnaud
well guys,
check that out :wink:
It's like IA has been listening to their users. :smiling_face_with_three_hearts:
Thanks guys for your handy tools , Do you think this brilliant CMMS Demo is enough to replace Maximo CMMS on client side , Or this is a basic one ?
Regards,
All depends on the functionalities that you or customer need. This CMMS is quite basic but:
  • It integrates well with Ignition
  • Is open source, so you can change add functionalities
  • Easy access to PLC/Device data to trigger maintenance do analytics
If you can share with us your need we can guide you further :slight_smile:
Regards
Many thanks. I also wanted to mention that last month, MaintainX and Inductive Automation launched an integration for automated maintenance.
You can find more information here:
1- Ignition Third-Party Module Showcase
2- Ignition Module - Setup and Configuration Guide | MaintainX Help Center
They offer a free basic setup that can perform similar functions to your Ignition project and can be scaled up in the future at an additional cost.
Regards,
