I use multiple monitors, when a pop up is called in designer it always appears on a monitor other than the focus monitor. I want to change this behavior. How do I force pop-up / option screen(s) to appear on the same monitor as the designer is displayed on?
What about when the screen resolution changes and the right-click menu ends up appearing on one of your other monitors? I usually have to end up closing out and opening the designer again when that happens.
What OS are you using? I have the same behavior on Windows. I believe this issue has to do with Windows not Ignition.
It's a Java/Windows thing. A couple relevant threads:
