Digital Signature
Hi Guys
We have put some forms onto ignition, they need an acknowledgement signature, however I can’t seem to find anything in ignition for doing this. I am recording all the form entries to a database and would like to attach a digital signature to it, ideally for cost a hand drawing input box would be good, however if not I am open to ideas.
Thanks in advance
ps (I did find this topic, but the link is broken :frowning: http://forum.inductiveautomation.com/t/anyone-used-digital-signature-pad/10224 )
I created a Cloud Template (Designer -> Tools -> Cloud Templates) called the “Drawable Canvas” that extends the paintable canvas and allows you to hand-draw onto an Ignition component.
You could pair this with the system.print.createImage function to turn the drawn signature into a raw image, which you could then store into the DB as a BLOB.
Perfect!! Thank you very much
To save others further Googling if they come upon this thread now like I did, Cloud Templates no longer exist and were replaced with Exchange (go to https://inductiveautomation.com/exchange/567/overview to download the Drawable Canvas instead), and to get the data from the image returned using system.print.createImage as a byte array you need to import javax.imageio and java.io ByteArrayOutputStream.
Something like this, where event.source is the Drawable Canvas component, should get you your signature/image as bytes:
from javax.imageio import ImageIO
from java.io import ByteArrayOutputStream
im = system.print.createImage(event.source)
baos = ByteArrayOutputStream()
ImageIO.write(im, “PNG”, baos)
imAsBytes = baos.toByteArray()
