Disable/enable alarm without using Tag in script
Hello
Is it possible to directly write on alarm enable field in script?
I don’t want to bind a tag to this property to do this. I have 5000 Data type which adding this tag enable/disable tag to it cause 5000 more tag to system which is not wise for resource and performance.
bump
Hi
I use parameters in expression on enable property of the alarm and it did work for me.
Hmm, and then you change the parameter through a script i guess?
No I use binding expression
