Is it possible to install Ignition 7.4 on the same server (Windows 2003) that is currently running FPMI 3.3/FSQL 4.2?
Also, my customer has been using RDP to access FPMI from their cell phones, what would be the advantage of using the Mobile Module instead of RDP? How can I justify the cost of the Mobile Module over their current RDP set-up?
Yes, it is possible to run two Ignition’s on the same machine. It just means they have to run on separate TCP ports. One will be 8088 and the other can be 8089. This file:
Unzip the file, change the ports in the xml file, and double click on the run-ignition.bat file to start it up. Don’t install a second Windows service though.
As far as the mobile goes, there is no advantage to using mobile over RDP. Both of them use resources on the server. So you can continue using RDP if that works for you. I guess the only advantage is being able to run on mobile devices without an RDP application.
I read the post wrong. You don’t have to do the steps above just to run Ignition next to FactorySQL and FactoryPMI. All you have to do is simply run the installer. There are no issues having Ignition and FactorySQL and FactoryPMI on the same machine.
