[DUPLICATE]Cannot open vision screen from restored gateway
When restoring a 7.9 backup to Ignition 8, I wasn’t able to open one vision screen (neither in the designer nor in the client).
I thought the problem was this script in the “InternalFrameOpened” event:
system.gui.getParentWindow(event).getComponentForPath('Root Container.txtUser').requestFocusInWindow()
As I couldn’t open the screen in the designer, I had to modify it in 7.9, and import it again. But even with the new import, it doesn’t seem to work.
In any case, IMHO, a bug in a script shouldn’t be able to break the designer interface.
08:42:15.494 [AWT-EventQueue-0] ERROR com.inductiveautomation.factorypmi.application.model.WindowCache - Unable to open window "Main windows/winLogin".
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected parsing error during binary deserialization.
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:358)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:360)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:303)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:277)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3489)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1294)
	at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.open(WindowNode.java:270)
	at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:179)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:655)
Caused by: org.apache.commons.io.IOExceptionWithCause: java.lang.ClassNotFoundException: com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField$SafeFocusHighlightBorder
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:395)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:356)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readAttributes(BinaryParser.java:179)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:148)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
	... 22 common frames omitted
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField$SafeFocusHighlightBorder
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Unknown Source)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForNameImpl(ClassNameResolver.java:196)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForName(ClassNameResolver.java:169)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:385)
	... 36 common frames omitted
Apparently it's this issue, though I don't know why I didn't get the latest nightly this morning ...
