I have a situation where I need to handle an exception due to an ArrayIndexOutOfBoundsException. In the manual, it says that this can be called out for an exception-specific failover. However, another error is thrown saying that ‘ArrayIndexOutOfBoundsException’ is not defined.
Using the example code from the manual, this is the code I’m trying to use.
myDataset = system.dataset.toDataSet([“colName”], [[0]])
try:
print myDataset.getValueAt(0,5)
except ArrayIndexOutOfBoundsException:
print “Index Out of Bounds”
Any thoughts would be very helpful.
