Export/Import users
I should want export and import from an internal users source on a gateway to another gateway.
Is it possible? How I can do this?
There's no trivial way to do this - other than restore a .gwbk, then delete the settings/projects/etc you don't need. That's by far the best option.
If you do want to go down the route of doing it manually, follow essentially the procedure I outlined here, except your destination will be another gateway's config.idb.:
Thanks,
I can connect to config.idb and execute insert directly?
