I am seeing the same issue as this post: Native client launcher - Missing fullscreen mode… Basically, I have a project that is set to launch in Full Screen mode, but it will only launch in Windowed mode. I have updated the project and made sure it is published. I can launch the project from designer in Full Screen mode, but when I use the Client Launcher it will only launch in Windowed mode. I even tried to update the Client Launcher generated project link on the desktop with “windowmode=fullscreen” but I get the error that there isn’t a launchable project with that configuration on the gateway.
I have v7.9.10 and have tried uninstalling and re-installing both the Client Launcher and even Ignition itself. After both instances, the print out from localhost:8080/main/system/projectlist/ is exactly the same.
I didn’t see any explicit fix to this issue from the previous post, so I figured I’d bring the topic back up.
