Gateway Event Auditing
So I know we have an audit journal that captures everything that happens within a project, but is there a way to capture what happens on a gateway level?
Say for example someone tinkers about with alarm settings and breaks them often and you want a smoking gun to remove their login?
Unfortunately, the audit system does not record events in the gateway config page.
On a side note, you could revoke access to one user at a time to those that can get on the config page, and see when the changes stop? Although that could be a long and tedious witch hunt. Sorry I can’t offer more. :frowning:
Audit for gateway is important for admin to trace all the work done on the gateway. Is gateway event auditing available in the latest version?
I will bump this thread. Will add it to the ideas site if its still up.
https://inductiveautomation.canny.io/ignition-features-and-ideas/p/audit-log-for-gateway-changes-and-user-management
Gateway event auditing is live in 7.9.13 and going to land in 8.0 soon, likely 8.0.9.
Awesome! Thanks guys.
