Get screen pixel color
Hi All,
Working in Perspective, Gateway 8.0.16.
I’m attempting to get the color of a pixel at the user’s mouse coordinates.
I found this forum post from over a decade ago, which solved the problem in Vision with a few lines of Java.
Updating the original solution for Perspective, I put the following code in my view.root’s mouse OnClick event:
	import java.awt.Robot
	robot = java.awt.Robot()
	try:
		x = event.clientX
		y = event.clientY
		colour = robot.getPixelColor(x, y)
		system.perspective.print('Color: ' + str(colour))
	except Exception as e:
		system.perspective.print(str(e))
The code doesn’t error out, but it always prints
Color: java.awt.Color[r=0,g=0,b=0],
even though the root is completely colored (not black). Anybody know if this solution should port over to Perspective, or another way to get color of a specific pixel?
Thanks in advance.
It does not. Someone would probably have to write a “Color Picker” component Module with the SDK to extend Perspective with this.
You can’t use Java methods directly, and even in a Perspective module you’ll have a hard time doing this in a satisfactory way. You can only retrieve colors from HTML canvas elements, or images converted into canvas elements, it looks like; and even then, only from the same origin (due to browser security restrictions).
A potentially better option, but one highly dependent on your environment, would be a color input element, which might, depending on your browser + platform, have an eyedropper:
https://developer.mozilla.org/en-US/docs/Web/HTML/Element/input/color
But that would be very flakey, and requires a custom module as well.
Thanks for the help @pturmel and @paul-griffith.
