The system.util.getGatewayAddress() is only available in the client scope.
I would like to obtain the gatewayAddress in the gateway scope ?
Which one should it return? There’s at least two, counting localhost. Could be many more. From a client, there’s only the one it actually reached, so it is unambiguous. The best you can do is enumerate your local addresses using Java’s NetworkInterface class.
Unless you are a module developer working on RPC – that has access to the client session within gateway scope.
my need is to execute a traits in gateway scope only is the gateway has a particular ip.
A gateway backup can be restored on multiple pc on our network, and I want some traits only execute on the main server.
Then java’s NetworkInterface class is your friend. Loop through your network interfaces checking each one’s list of addresses.
Thanks a lot
