Hello @bkarabinchak.psi ,
Can you help us how to handle it.
Please refer the
print system.db.runUpdateQuery(" DECLARE @sql NVARCHAR(MAX); SET @sql = ' CREATE PROCEDURE PlannedDowntime @Int INT,@Int1 INT,@Result Decimal(16,4) output AS BEGIN SET NOCOUNT ON; Declare @Result_TPM Decimal(16,4) Set@Result_TPM =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'TPM' AND pdt IS NOT NULL) Declare @Result_Break Decimal(16,4) Set @Result_Break =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'BRK' AND pdt IS NOT NULL) Declare @Result_WGBT Decimal(16,4) Set @Result_WGBT =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'WGBT' AND pdt IS NOT NULL) Set @Result =( ISNULL(@Result_TPM,0) + ISNULL(@Result_Break,0) + ISNULL(@Result_WGBT,0) ) return @Result END '; EXEC (@sql);" , "ignitiondb", True)
I have checked same query into SSMS & it creating store procedure
CREATE PROCEDURE PlannedDowntime @Int INT,@Int1 INT,@Result Decimal(16,4) output AS BEGIN SET NOCOUNT ON; Declare @Result_TPM Decimal(16,4) Set @Result_TPM =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'TPM' AND pdt IS NOT NULL) Declare @Result_Break Decimal(16,4) Set @Result_Break =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'BRK' AND pdt IS NOT NULL) Declare @Result_WGBT Decimal(16,4) Set @Result_WGBT =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'WGBT' AND pdt IS NOT NULL) Set @Result =( ISNULL(@Result_TPM,0) + ISNULL(@Result_Break,0) + ISNULL(@Result_WGBT,0) ) return @Result END
Error in script consol:
Java Traceback:
File "<input>", line 14, in <module>
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188)
at jdk.internal.reflect.GeneratedMethodAccessor126.invoke(Unknown Source)
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery( DECLARE @sql NVARCHAR(MAX); SET @sql = ' CREATE PROCEDURE PlannedDowntime @Int INT,@Int1 INT,@Result Decimal(16,4) output AS BEGIN SET NOCOUNT ON; Declare @Result_TPM Decimal(16,4) Set @Result_TPM =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'TPM' AND pdt IS NOT NULL) Declare @Result_Break Decimal(16,4) Set @Result_Break =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'BRK' AND pdt IS NOT NULL) Declare @Result_WGBT Decimal(16,4) Set @Result_WGBT =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'WGBT' AND pdt IS NOT NULL) Set @Result =( ISNULL(@Result_TPM,0) + ISNULL(@Result_Break,0) + ISNULL(@Result_WGBT,0) ) return @Result END '; EXEC (@sql);, Transaction datasource unknown, true, true)
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:512)
at org.python.core.PyObject.__call__(PyObject.java:517)
at org.python.pycode._pyx236.f$0(<input>:14)
at org.python.pycode._pyx236.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery( DECLARE @sql NVARCHAR(MAX); SET @sql = ' CREATE PROCEDURE PlannedDowntime @Int INT,@Int1 INT,@Result Decimal(16,4) output AS BEGIN SET NOCOUNT ON; Declare @Result_TPM Decimal(16,4) Set @Result_TPM =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'TPM' AND pdt IS NOT NULL) Declare @Result_Break Decimal(16,4) Set @Result_Break =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'BRK' AND pdt IS NOT NULL) Declare @Result_WGBT Decimal(16,4) Set @Result_WGBT =(SELECT SUM (Duration) FROM cm_shiftSchedule WHERE entityID = 13 AND shiftDay = Convert(Date,(GetDate())) AND pdtCode = 'WGBT' AND pdt IS NOT NULL) Set @Result =( ISNULL(@Result_TPM,0) + ISNULL(@Result_Break,0) + ISNULL(@Result_WGBT,0) ) return @Result END '; EXEC (@sql);, Transaction datasource unknown, true, true)
... 25 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Connection Error: Transaction "true" is closed.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runUpdateQuery(ClientDBUtilities.java:267)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
... 23 more
Caused by: java.sql.SQLException: Transaction "true" is closed.
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.getTx(DatasourceManagerImpl.java:292)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl.getTransactionConnection(DatasourceManagerImpl.java:299)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.getConnection(GatewayDBUtilities.java:99)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:50)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
at java.lang.Thread.run(null)
Please help to resolve issue
Regards,
Dhiraj Pawar
