I have uninstalled and reinstalled Ignition
i see the
Ignition is starting logo but nothing happens
It has worked on my pc before.
Im using Vista home and fire fox.
Any suggestions.
Regards
Rafey
i see the
Any suggestions.
Regards
Rafey
Can you attach the “wrapper.log” file from the install directory? Maybe something is happening during startup, or at least we should be able to tell how far it gets.
Regards,
WARN | wrapper | 2011/03/11 18:02:11 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/03/11 18:02:11 | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | 2011/03/11 18:02:11 | trying the system encoding.
ERROR | wrapper | 2011/03/11 18:02:11 | Unable to install the Ignition Gateway service - The specified service has been marked for deletion. (0x430)
WARN | wrapper | 2011/03/11 18:19:47 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/03/11 18:19:47 | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | 2011/03/11 18:19:47 | trying the system encoding.
ERROR | wrapper | 2011/03/11 18:19:47 | Unable to install the Ignition Gateway service - The specified service has been marked for deletion. (0x430)
WARN | wrapper | 2011/03/11 18:30:42 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/03/11 18:30:42 | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | 2011/03/11 18:30:42 | trying the system encoding.
ERROR | wrapper | 2011/03/11 18:30:42 | Unable to install the Ignition Gateway service - The specified service has been marked for deletion. (0x430)
WARN | wrapper | 2011/03/11 18:40:30 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/03/11 18:40:30 | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | 2011/03/11 18:40:30 | trying the system encoding.
STATUS | wrapper | 2011/03/11 18:40:30 | Ignition Gateway service installed.
WARN | wrapper | 2011/03/11 18:40:32 | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | 2011/03/11 18:40:32 | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | 2011/03/11 18:40:32 | trying the system encoding.
STATUS | wrapper | 2011/03/11 18:40:32 | Starting the Ignition Gateway service…
STATUS | wrapper | 2011/03/11 18:40:32 | --> Wrapper Started as Service
STATUS | wrapper | 2011/03/11 18:40:32 | Java Service Wrapper Standard Edition 32-bit 3.5.4
STATUS | wrapper | 2011/03/11 18:40:32 | Copyright © 1999-2010 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2011/03/11 18:40:32 | wrapper.tanukisoftware.com
STATUS | wrapper | 2011/03/11 18:40:32 | Licensed to Inductive Automation for Ignition Gateway
STATUS | wrapper | 2011/03/11 18:40:32 | Launching a JVM…
INFO | jvm 1 | 2011/03/11 18:40:33 | WrapperManager: Initializing…
INFO | wrapper | 2011/03/11 18:40:37 | Waiting to start…
STATUS | wrapper | 2011/03/11 18:40:38 | Ignition Gateway started.
INFO | jvm 1 | 2011/03/11 18:41:09 | Mar 11, 2011 6:41:09 PM org.apache.catalina.startup.Embedded start
INFO | jvm 1 | 2011/03/11 18:41:09 | INFO: Starting tomcat server
INFO | jvm 1 | 2011/03/11 18:41:09 | Mar 11, 2011 6:41:09 PM org.apache.catalina.core.StandardEngine start
INFO | jvm 1 | 2011/03/11 18:41:09 | INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
INFO | jvm 1 | 2011/03/11 18:41:09 | Mar 11, 2011 6:41:09 PM org.apache.catalina.startup.DigesterFactory register
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_0.xsd
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_1.xsd
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_1.dtd
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_2.dtd
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_0.xsd
INFO | jvm 1 | 2011/03/11 18:41:09 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_1.xsd
INFO | jvm 1 | 2011/03/11 18:41:12 | INFO [SRClassLoader ] [18:41:12,267]: SRClassLoader init
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SRContext ] [18:41:13,191]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [BundleUtil ] [18:41:13,213]: Requested load of resource bundle ‘common’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SRContext ] [18:41:13,218]: Starting Ignition 7.2.4 (b48)
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SRContext ] [18:41:13,219]: Reloading JDBC classloader.
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SecureRandomProvider ] [18:41:13,520]: Creating SecureRandom object…
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SecureRandomProvider ] [18:41:13,521]: Generating seed…
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SecureRandomProvider ] [18:41:13,523]: … Seed Created.
INFO | jvm 1 | 2011/03/11 18:41:13 | INFO [SecureRandomProvider ] [18:41:13,524]: … SecureRandom Created.
INFO | jvm 1 | 2011/03/11 18:41:14 | WARN [PersistentProperties ] [18:41:14,627]: File “gateway.xml” not found, copying from clean version: “gateway.xml_clean”
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [BundleUtil ] [18:41:15,318]: Requested load of resource bundle ‘common’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [BundleUtil ] [18:41:15,322]: Requested load of resource bundle ‘gateway’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [Application ] [18:41:15,481]: [SRContext] init: Wicket core library initializer
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,484]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,485]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,486]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,487]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,487]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,488]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [RequestListenerInterface ] [18:41:15,489]: registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [Application ] [18:41:15,489]: [SRContext] init: Wicket extensions initializer
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [WebApplication ] [18:41:15,538]: [SRContext] Started Wicket version 1.4.5 in deployment mode
INFO | jvm 1 | 2011/03/11 18:41:15 | INFO [StateMonitoring ] [18:41:15,555]: The cluster node state has changed. Current state: [RedundancyState[role=Independent, activity level=Active, project state=Good, history level=Full]
INFO | jvm 1 | 2011/03/11 18:41:15 | Mar 11, 2011 6:41:15 PM org.apache.coyote.http11.Http11Protocol init
INFO | jvm 1 | 2011/03/11 18:41:15 | SEVERE: Error initializing endpoint
INFO | jvm 1 | 2011/03/11 18:41:15 | java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2011/03/11 18:41:15 | at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:502)
INFO | jvm 1 | 2011/03/11 18:41:15 | at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
INFO | jvm 1 | 2011/03/11 18:41:15 | at org.apache.catalina.connector.Connector.initialize(Connector.java:1058)
INFO | jvm 1 | 2011/03/11 18:41:15 | at org.apache.catalina.startup.Embedded.start(Embedded.java:830)
INFO | jvm 1 | 2011/03/11 18:41:15 | at com.inductiveautomation.catapult.CatapultBase.startTomcat(CatapultBase.java:207)
INFO | jvm 1 | 2011/03/11 18:41:15 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:82)
INFO | jvm 1 | 2011/03/11 18:41:15 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2011/03/11 18:41:15 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:272)
INFO | jvm 1 | 2011/03/11 18:41:15 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp:
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: java.lang.RuntimeException: LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:84)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:272)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: Caused by: LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at org.apache.catalina.connector.Connector.initialize(Connector.java:1060)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at org.apache.catalina.startup.Embedded.start(Embedded.java:830)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.CatapultBase.startTomcat(CatapultBase.java:207)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:82)
INFO | jvm 1 | 2011/03/11 18:41:15 | WrapperSimpleApp Error: … 6 more
INFO | jvm 1 | 2011/03/11 18:41:17 | Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
STATUS | wrapper | 2011/03/11 18:41:18 | <-- Wrapper Stopped
Here's what I was looking for:
Something else on your machine is already using the port that Ignition is trying to use. As you can imagine, this is a big problem for a web-server based product.
You can change the port for Ignition by editing "config.xml" in the install directory. Change the port to something else, like 8090, and try starting it again. After changing it, you will of course need to access the gateway with that port, for example "http://localhost:8090".
Regards,
thanks it works
