Any tips to get this back up and running quick? It looks like this issue: Gateway is not starting and is on the same OS, but a Beckhoff IPC with capacitor UPS (very short hold up time, intended to allow controlled shutdown in case of power loss but may not if things take long to shutdown).
Wrapper.log:
WARN   | wrapperm | 2021/03/22 09:05:36 | The "wrapper.java.command" property was redefined on line #46 of configuration file: C:\Program Files\Inductive Automation\Ignition\data\ignition.conf
WARN   | wrapperm | 2021/03/22 09:05:36 |   Old Value wrapper.java.command=lib/runtime/jre-win/bin/java
WARN   | wrapperm | 2021/03/22 09:05:36 |   New Value wrapper.java.command=%JAVA_HOME%/bin/java
STATUS | wrapperm | 2021/03/22 09:05:36 | Starting the Ignition Gateway service...
WARN   | wrapper  | 2021/03/22 09:05:36 | The "wrapper.java.command" property was redefined on line #46 of configuration file: C:\Program Files\Inductive Automation\Ignition\data\ignition.conf
WARN   | wrapper  | 2021/03/22 09:05:36 |   Old Value wrapper.java.command=lib/runtime/jre-win/bin/java
WARN   | wrapper  | 2021/03/22 09:05:36 |   New Value wrapper.java.command=%JAVA_HOME%/bin/java
STATUS | wrapper  | 2021/03/22 09:05:36 | --> Wrapper Started as Service
STATUS | wrapper  | 2021/03/22 09:05:36 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper  | 2021/03/22 09:05:36 |   Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper  | 2021/03/22 09:05:36 |     http://wrapper.tanukisoftware.com
STATUS | wrapper  | 2021/03/22 09:05:36 |   Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper  | 2021/03/22 09:05:37 | Launching a JVM...
INFO   | jvm 1    | 2021/03/22 09:05:37 | WrapperManager: Initializing...
INFO   | jvm 1    | 2021/03/22 09:05:40 | 09:05:40,373 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO   | jvm 1    | 2021/03/22 09:05:40 | 09:05:40,390 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO   | jvm 1    | 2021/03/22 09:05:40 | 09:05:40,408 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO   | jvm 1    | 2021/03/22 09:05:40 | 09:05:40,504 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO   | jvm 1    | 2021/03/22 09:05:40 | 09:05:40,536 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO   | wrapperm | 2021/03/22 09:05:41 | Waiting to start...
STATUS | wrapperm | 2021/03/22 09:05:42 | Ignition Gateway service started.
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,605 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@3dc16521 - Driver name=SQLite JDBC
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,606 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@3dc16521 - Driver version=3.23.1
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,606 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@3dc16521 - supportsGetGeneratedKeys=true
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,773 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,780 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,785 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,786 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,788 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,789 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,789 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,790 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,790 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,790 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,791 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,792 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,796 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,796 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO   | jvm 1    | 2021/03/22 09:05:41 | 09:05:41,798 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@65f692c1 - Registering current configuration as safe fallback point
INFO   | jvm 1    | 2021/03/22 09:05:41 | Scheduling logfile maintenance. Last maintenance: Wed Dec 31 17:00:00 MST 1969, events since then: 0
INFO   | jvm 1    | 2021/03/22 09:05:41 | Starting logfile maintenance. Max entries: 50000
INFO   | jvm 1    | 2021/03/22 09:05:41 | Cleaned up 40 rows in 26 ms. Vacuum performed: false
INFO   | jvm 1    | 2021/03/22 09:05:42 | 09:05:41,949 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@781eb4b2 - Propagating INFO level on Logger[ROOT] onto the JUL framework
INFO   | jvm 1    | 2021/03/22 09:05:42 | W [WebResourceManagerImpl        ] [15:05:42]: Unable to read "gateway.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO   | jvm 1    | 2021/03/22 09:05:43 | I [o.e.j.u.log                   ] [15:05:43]: Logging initialized @5941ms to org.eclipse.jetty.util.log.Slf4jLog
INFO   | jvm 1    | 2021/03/22 09:05:43 | W [IgnitionServer                ] [15:05:43]: Error updating new default trust store
INFO   | jvm 1    | 2021/03/22 09:05:43 | java.io.IOException: toDerInputStream rejects tag type 0
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/sun.security.util.DerValue.toDerInputStream(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/sun.security.util.KeyStoreDelegator.engineLoad(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/java.security.KeyStore.load(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.catapult.IgnitionServer.importSupplementalCertificates(IgnitionServer.java:1115)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.catapult.IgnitionServer.<init>(IgnitionServer.java:183)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.<init>(WebResourceManagerImpl.java:156)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.<init>(IgnitionGateway.java:497)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:286)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO   | jvm 1    | 2021/03/22 09:05:43 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:43 | I [g.WebServerManager            ] [15:05:43]: Starting setup
INFO   | jvm 1    | 2021/03/22 09:05:43 | I [g.WebServerManager            ] [15:05:43]: Setup complete
INFO   | jvm 1    | 2021/03/22 09:05:44 | I [g.WebServerManager            ] [15:05:44]: Starting up
INFO   | jvm 1    | 2021/03/22 09:05:45 | W [g.CertificateValidationUtil   ] [15:05:45]: Cert with subject 'CN=Ignition, OU=Ignition Gateway, O=Inductive Automation, L=Folsom, ST=CA, C=US' has no basic constraints.
INFO   | jvm 1    | 2021/03/22 09:05:45 | W [g.SslManager                  ] [15:05:45]: Unable to verify chain of trust state=NO_CERTIFICATE
INFO   | jvm 1    | 2021/03/22 09:05:45 | java.lang.Exception: PKIX certificate path validation failed
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.CertificateValidationUtil.verifyTrustChain(CertificateValidationUtil.java:292)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.CertificateValidationUtil.verifyTrustChain(CertificateValidationUtil.java:109)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.SslManager.validateKeyStore(SslManager.java:260)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.SslManager$AbstractStateReader.readState(SslManager.java:300)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.SslManager.refreshInternal(SslManager.java:439)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.SslManager.startup(SslManager.java:459)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.catapult.IgnitionServer.setupConnectors(IgnitionServer.java:1043)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.catapult.IgnitionServer.<init>(IgnitionServer.java:261)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.web.WebResourceManagerImpl.<init>(WebResourceManagerImpl.java:156)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.<init>(IgnitionGateway.java:497)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.main(IgnitionGateway.java:286)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.catapult.Catapult.main(Catapult.java:8)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/java.security.cert.PKIXParameters.setTrustAnchors(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/java.security.cert.PKIXParameters.<init>(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at java.base/java.security.cert.PKIXBuilderParameters.<init>(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	at com.inductiveautomation.ignition.gateway.ssl.CertificateValidationUtil.verifyTrustChain(CertificateValidationUtil.java:230)
INFO   | jvm 1    | 2021/03/22 09:05:45 | 	... 17 common frames omitted
INFO   | jvm 1    | 2021/03/22 09:05:45 | I [g.SslManager                  ] [15:05:45]: State refreshed state=LEGACY_SELF_SIGNED_CERTIFICATE
INFO   | jvm 1    | 2021/03/22 09:05:45 | I [C.SecureRandomProvider        ] [15:05:45]: Secure random seed generated in 1ms
INFO   | jvm 1    | 2021/03/22 09:05:45 | I [o.e.j.s.Server                ] [15:05:45]: jetty-9.4.24.v20191120; built: 2019-11-20T21:37:49.771Z; git: 363d5f2df3a8a28de40604320230664b9c793c16; jvm 11.0.9+11-LTS
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.e.j.s.session               ] [15:05:46]: DefaultSessionIdManager workerName=node0
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.e.j.s.session               ] [15:05:46]: No SessionScavenger set, using defaults
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.e.j.s.session               ] [15:05:46]: node0 Scavenging every 600000ms
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.Application             ] [15:05:46]: [WicketFilter] init: Wicket core library initializer
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.RequestListenerInterface] [15:05:46]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO   | jvm 1    | 2021/03/22 09:05:46 | I [o.a.w.Application             ] [15:05:46]: [WicketFilter] init: Wicket extensions initializer
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [IgnitionGateway               ] [15:05:46]: Ignition[state=STOPPED] ContextState = STARTING
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [o.a.w.p.h.WebApplication      ] [15:05:46]: [WicketFilter] Started Wicket version 6.3.0 in DEPLOYMENT mode
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [IgnitionGateway               ] [15:05:47]: Starting Ignition 8.1.2 (b2021020311)
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [IgnitionGateway               ] [15:05:47]: Reloading JDBC classloader.
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [o.e.j.s.h.ContextHandler      ] [15:05:47]: Started c.i.c.MainWebAppContext@2d9bd9ba{Ignition,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [R.S.S.InternalDb              ] [15:05:47]: Internal db synchronizer disk cache initialized. State id=0cbf62a4-6af6-46ee-85d5-30b66284802c
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [R.StateMonitoring             ] [15:05:47]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [o.e.j.s.AbstractConnector     ] [15:05:47]: Started ServerConnector@79b8bd21{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO   | jvm 1    | 2021/03/22 09:05:47 | I [o.e.j.u.s.SslContextFactory   ] [15:05:47]: x509=X509@48a3e2e3(ignition,h=[],w=[]) for Server@5ca04ae4[provider=null,keyStore=null,trustStore=null]
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [g.InternalDatabaseManager     ] [15:05:48]: Starting up...
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [P.InternalDatabase            ] [15:05:48]: Looking for existing internal database "config.idb"...
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [P.InternalDatabase            ] [15:05:48]: ... found existing.
INFO   | jvm 1    | 2021/03/22 09:05:48 | WARNING: An illegal reflective access operation has occurred
INFO   | jvm 1    | 2021/03/22 09:05:48 | WARNING: Illegal reflective access by com.inductiveautomation.ignition.gateway.util.IgnitionSocketImplFactory (file:/C:/Program%20Files/Inductive%20Automation/Ignition/lib/core/gateway/gateway-8.1.2.jar) to constructor java.net.SocksSocketImpl()
INFO   | jvm 1    | 2021/03/22 09:05:48 | WARNING: Please consider reporting this to the maintainers of com.inductiveautomation.ignition.gateway.util.IgnitionSocketImplFactory
INFO   | jvm 1    | 2021/03/22 09:05:48 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO   | jvm 1    | 2021/03/22 09:05:48 | WARNING: All illegal access operations will be denied in a future release
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [o.e.j.s.AbstractConnector     ] [15:05:48]: Started ServerConnector@386b785{SSL,[ssl, http/1.1]}{0.0.0.0:8043}
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [P.InternalDatabase            ] [15:05:48]: internal database "config.idb" started up successfully.
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [P.InternalDatabase            ] [15:05:48]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [o.e.j.s.AbstractConnector     ] [15:05:48]: Started ServerConnector@36c4d0c1{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO   | jvm 1    | 2021/03/22 09:05:48 | I [o.e.j.s.Server                ] [15:05:48]: Started @11447ms
INFO   | jvm 1    | 2021/03/22 09:05:49 | E [C.BasicExecutionEngine        ] [15:05:49]: One-shot task com.inductiveautomation.ignition.gateway.IgnitionGateway$$Lambda$329/0x00000001003fe040@1bc2398d threw uncaught exception.
INFO   | jvm 1    | 2021/03/22 09:05:49 | java.lang.InternalError: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.net.http/jdk.internal.net.http.HttpClientImpl.<init>(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.net.http/jdk.internal.net.http.HttpClientImpl.create(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.net.http/jdk.internal.net.http.HttpClientBuilderImpl.build(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.licensing.LicenseManagerImpl.createLeasedActivationStrategy(LicenseManagerImpl.java:154)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.licensing.LicenseManagerImpl.<init>(LicenseManagerImpl.java:118)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.init(ModuleManagerImpl.java:357)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:865)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:293)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:724)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:658)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | Caused by: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.security.Provider$Service.newInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.jca.GetInstance.getInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/javax.net.ssl.SSLContext.getInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/javax.net.ssl.SSLContext.getDefault(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	... 17 common frames omitted
INFO   | jvm 1    | 2021/03/22 09:05:49 | Caused by: java.security.KeyStoreException: problem accessing trust store
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.TrustManagerFactoryImpl.engineInit(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/javax.net.ssl.TrustManagerFactory.init(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.SSLContextImpl$DefaultManagersHolder.getTrustManagers(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.SSLContextImpl$DefaultManagersHolder.<clinit>(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.SSLContextImpl$DefaultSSLContext.<init>(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.security.Provider.newInstanceUtil(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	... 22 common frames omitted
INFO   | jvm 1    | 2021/03/22 09:05:49 | Caused by: java.io.IOException: toDerInputStream rejects tag type 0
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.util.DerValue.toDerInputStream(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.util.KeyStoreDelegator.engineLoad(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/java.security.KeyStore.load(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.TrustStoreManager$TrustAnchorManager.loadKeyStore(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.TrustStoreManager$TrustAnchorManager.getTrustedCerts(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	at java.base/sun.security.ssl.TrustStoreManager.getTrustedCerts(Unknown Source)
INFO   | jvm 1    | 2021/03/22 09:05:49 | 	... 32 common frames omitted
