There are instances when a module uses a custom dll/library loaded using System.loadLibrary(“abcd”) .
The dll must be unloaded when the shutting down/removing a module, or else subsequent loadLibrary() calls won’t work.
A nice hack was posted a while back, it worked fine in Ignition 7: Module using dll - unloading?.
try {
ClassLoader classLoader = this.getClass().getClassLoader();
Field field = ClassLoader.class.getDeclaredField("nativeLibraries");
field.setAccessible(true);
@SuppressWarnings("unchecked")
Vector<Object> libs = (Vector<Object>) field.get(classLoader);
for (Object o : libs) {
Method finalize = o.getClass().getDeclaredMethod("finalize", new Class[0]);
finalize.setAccessible(true);
finalize.invoke(o, new Object[0]);
} catch (Throwable t) {
lg.tologFatal(true, "Error unloading native resources. " + t.toString());
This hack does not work in Ignition 8, is there an alternative solution?
The line that fails is : Vector libs = (Vector) field.get(classLoader);
And the error is:
java.lang.ClassCastException: class java.util.concurrent.ConcurrentHashMap cannot be cast to class java.util.Vector (java.util.concurrent.ConcurrentHashMap and java.util.Vector are in module java.base of loader ‘bootstrap’)
