Ignition and Rockwell Emulate 5000/RSLinx Classic Gateway
Will Ignition read tags from an Emulate 5000 (v30) controller using RS Classic Gateway 4.1? I’ve read a lot of old threads here and elsewhere and still not sure about the answer.
So far, I have a successful connection to the local RSLinx OPC Server with the OPC-DA COM Connection. I can see the Linx OPC Servers and tags if I go to OPC Quick Client in the config menu. But now I’m at a roadblock. Is that as far as this goes with this combination of software?
As you can see, I can find all the tags in the Tag Browser and D&D them, but they all have errors…
Those instructions in the first post did it! Looks good now.
