Hello, I’m trying to get a gateway script to trigger at the top of the minute, every minute; Example being it fires at 08:00:00, 08:01:00, 08:02:00. I know I can set a gateway script to run every minute, but is it possible to get it to fire at the top of every minute?
I mostly just want to check if anyone knows of any updated features that would work instead of doing it this way; or anyone that is currently doing it, what their thoughts are on it. Thank you!
How accurate do you need it to be? Even a cron-style interface to a thread pool executor can have lag for a task defined to start at the top of the minute. If you need fractional-second accuracy, you probably need to use a permanent sleeping background thread that computes the precise sleep time needed on each iteration.
Within a couple seconds max, I don’t think it has to be super super precise but would prefer it just triggers a small sql script at the start of every minute for logging. It takes no time to run at all, I just want to have it run at the top of every minute
I would do it this way, depending on what is involved with the SQL end, YMMV
#Create a Gateway Timer Script, insert the code below
#Set the gateway timer script to execute every 750mS, with *dedicated* threading
#Run a script at the start of every minute
from time import localtime, strftime
curTime = strftime("%S", localtime())
print curTime
if curTime == "00":
#At the start of every minute, run the script
shared.Minute.Run()
This approach isn’t as safe because it relies on your script actually executing on the 00 second of every minute. This probably happens most of the time, but may not happen all the time. You’re running on non-real-time hardware and a consumer OS in a garbage collected environment, after all…
Jordan’s works because the system would have to hang for an entire minute to skip an execution.
