Whenever I open a vision window(with objects on it) in the designer I receive the following error.
I am not certain what is causing it any guidance on where to look would be greatly appreciated.
java.lang.ClassCastException: Unable to create new interface java.awt.Paint. java.awt.Paint
at com.inductiveautomation.ignition.common.TypeUtilities$DefaultClassInitializer.createNew(TypeUtilities.java:1663)
at com.inductiveautomation.ignition.common.TypeUtilities.getInitValueForClass(TypeUtilities.java:1613)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:216)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.setQValue(SimpleBoundTagAdapter.java:245)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:262)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:498)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:487)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$TagChangeListenerProxy.tagChanged(DatasourceTagManager.java:1108)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.subscribe(DatasourceTagManager.java:299)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.subscribe(ClientTagManagerImpl.java:422)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.startup(SimpleBoundTagAdapter.java:140)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:332)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:348)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3575)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1333)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ResourceThumbnail.onClick(StartupPanel.java:339)
at com.inductiveautomation.factorypmi.designer.workspace.StartupPanel$ThumbnailButton$1.mouseClicked(StartupPanel.java:244)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Ignition v7.9.3 (b2017060210)
Java: Oracle Corporation 1.8.0_74
