I want to launch a client from another client holding another project.
system.util.retargeting() is not an option since that client is replaced by the "new" client and the old client gets closed/replaced.
Maybe is possible to use retargeting without closing the current client and open as a new instance??
Any advice?
The idea is to create a master project that manages the others.
Another option could be to launch the same client multiple times and from there I could use retargeting from one of a particular client.
This is driving me crazy since it's seems easy but it's actually hard.
Please help!!
Iād say you would have to use system.util.execute to create a new instance.
This does give a clue, however there's a couple things that are not clear for me:
I'm using V.8.0.9
First, should I find the path where visionclientlaucher. exe, I realized that in the documentation, they refer to it as "clientlauncher.exe". Is it the same?
Second, the rest of the command should something like this scope=C project=myproject windowmode=window
, but are those next command to perform in system.util.execute()
I mean:
system.util.execute(["C:\ClientLauncher\clientlauncher.exe", "application=myproject"])
or
system.util.execute(["C:\ClientLauncher\clientlauncher.exe application=myproject"])
or
system.util.execute(["C:\ClientLauncher\clientlauncher.exe" application=myproject])
Which should work?
I had checked:
But it's been applied for another purpose...
Thanks for reply Mr. @JordanCClark
Is the correct syntax. clientlauncher.exe
is the 7.9 and prior version's executable; visionclientlauncher.exe
is the 8.0 version executable.
Thanks MR. @PGriffith for clarification. Letās forget about .execute for a moment
I just want to launch a client executing a project from cmd (windows)
In cmd Iām running
This doesnāt not lunch the client, this launches the Vision Client Launcherā¦
I mean. I want the to run with a project and not the
Iāve been thinking on creating a āDesktop Shortcutā and then try to run it from the cmd. But itās kind of redundant.
Please some helpā¦
Try checking the visionclientlauncher.log
in .ignition/clientlauncher-data/
; you should see something like this; recreating that (not all of those parameters are strictly necessary) would be the way to directly launch a client, just like the launchers do themselves:
INFO [LaunchUtil ] [2020/01/15 09:18:53]: Starting Java with the following parameters: C:\Users\pgriffith\.ignition\clientlauncher-data\..\cache\resources\runtimes\11.0.5\bin\java.exe -classpath C:\Users\pgriffith\.ignition\clientlauncher-data\launchclient.jar -Djavaws.sr.gateway.addr.0=http://docker.ia.local:51942 -Djavaws.sr.launchts=1579108733090 -Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook -Djavaws.sr.platform.edition= -Xms32M -Xmx256M -Djavaws.sr.memory.init=32M -Djavaws.sr.memory.max=256M -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=C -Djavaws.sr.project=PR7942_Docker_20191211 com.inductiveautomation.ignition.client.launch.BootstrapSwing
mmm I seeā¦ I need to check this paraments cuz Iām getting an error
Ok Mr. @PGriffith, I successfully launched the client from cmd. Thanks!!
Now how can I apply this inside system.util.execute()
in a button from another Client.
Would be as easy to copy C:\Users\pgriffith.ignition\clientlauncher-ā¦
inside the function?
I feel Iām so close but nothing yet.
From cmd I can launch client, now the idea is to perform it from a button in another client
I tried system.util.execute([āC:\windows\system32\cmd.exeā,"/C",āstartā,"C:\Users\jespin\.
But this button is not doing nothing.
I addition I made a test on a button with:
system.util.execute([ānotepad.exeā,āc:\program files\inductive automation\ignition\license.txtā])
and works perfecty!!
Is something with the call from cmd that Iām not doing it right, please some helpā¦
I have this barely working, the client is launching but never complete the manifest
Itās been loading for more than a minuteā¦
Iāve seen so many option in the usage of ā/ā ā\ā āā and even with the single and double (ā āā). and I need some clarification because if use some of them I seems to be doing something and other times donāt
Hate to dig up a dead thread like this, but jcoffman's reply appears to have been removed, hoping you can help fill in the details here. I'm at the same point you were, launching from command line, but cannot seem to translate this to system.util.execute() with the information here and in the docs.
Where I'm at. The system provides no feedback, so it's tough to know where the error is here.
system.util.execute(["C:\\Users\\AIO\\.ignition\\cache\\resources\\runtimes\\11.0.16.1\\bin\\java.exe", "-classpath C:\\Users\\AIO\\.ignition\\cache\\resources\\platform\\launchclient.jar\\00000000EDEEDC49\\launchclient.jar", "-Djavaws.sr.gateway.addr.0=localhost:8088" "-Djavaws.sr.launchts=1697234442948", "-Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook", "-Djavaws.sr.platform.edition=", "-Djavaws.sr.platform.plugins=", "-Xms32M", "-Xmx256M", "-Djavaws.sr.memory.init=32M", "-Djavaws.sr.memory.max=256M", "-Dsun.java2d.d3d=false", "-Dsun.java2d.noddraw=false", "-Djavaws.sr.screen=0", "-Djavaws.sr.scope=C", "-Djavaws.sr.project=Project", "com.inductiveautomation.ignition.client.launch.BootstrapSwing"])
That does spark curiosity doesn't it? What sort of information did the post contain? Why was it necessary to remove it?
In any case, perhaps rewrite it like this to make it easier to spot typos:
"-classpath",
"C:\\Users\\AIO\\.ignition\\cache\\resources\\platform\\launchclient.jar\\00000000EDEEDC49\\launchclient.jar",
"-Djavaws.sr.gateway.addr.0=localhost:8088",
"-Xms32M",
"-Xmx256M",
Thank you, Justin.
The formatting feels like a facepalm moment in retrospect, and I appreciate you taking the time to fix my errors while you were at it.
Cheers!
Huh, thats weird about the post removal, I don't recall that.
iirc its more or less what Justin posted. You can see the launch command used in the /.ignition/clientlauncher-data/visionclientlauncher.log
file specifically and craft it from that.
That is, until the DeepLink support we add in 8.3
