Maven Build Issues for OPC-UA Driver Module in 7.9.1
Hello Everyone,
I am having issues completing the build for a custom driver module in Ignition.
I have realized that I am missing the AbstractDriverModuleHook but when I try to add the dependency according to advise on this post, the following error shows up.
[ERROR] Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.12:modl (default) on project snmpModule-build: Unable to parse configuration of mojo com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.12:modl for parameter moduleID: Cannot find 'moduleID' in class com.inductiveautomation.ignitionsdk.ModuleDepends -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginConfigurationException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :snmpModule-build
Here is my build file:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <groupId>com.citi.snmp</groupId>
        <artifactId>snmpModule</artifactId>
        <version>1.0.3</version>
    </parent>
    <artifactId>snmpModule-build</artifactId>
    <dependencies>
        <dependency>
            <artifactId>snmpModule-driver</artifactId>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <groupId>com.inductiveautomation.ignitionsdk</groupId>
                <artifactId>ignition-maven-plugin</artifactId>
                <version>1.0.12</version>
                <executions>
                    <execution>
                        <phase>package</phase>
                        <goals>
                            <goal>modl</goal>
                        </goals>
                    </execution>
                </executions>
                <configuration>
                    <projectScopes>
                        <projectScope>
                            <name>snmpModule-driver</name>
                            <scope>G</scope>
                        </projectScope>
                    </projectScopes>
                    <moduleId>com.citi.snmp</moduleId>
                    <moduleName>SNMPModule</moduleName>
                    <moduleDescription>${project.description}</moduleDescription>
                    <moduleVersion>1.0.3</moduleVersion>
                    <requiredIgnitionVersion>7.7.0</requiredIgnitionVersion>
                    <requiredFrameworkVersion>6</requiredFrameworkVersion>
					<depends>
    					<depend>
    						<scope>G</scope>
    						<moduleID>xopc</moduleID>
    					</depend>
   				 	</depends>
                    <hooks>
                        <hook>
                            <scope>G</scope>
                            <hookClass>com.citi.snmp.DriverHook</hookClass>
                        </hook>
                    </hooks>
                </configuration>
            </plugin>
        </plugins>
    </build>
</project>
I was able to finally get the project to upload. The section must have had an extra space somewhere because when I pasted it in from the abstract-tag-driver example it worked.
You had an XML tag with the wrong capitalization (“moduleID” vs “moduleId”):
<depends>
	<depend>
		<scope>G</scope>
	</depend>
</depends>
