I’ve been connecting to a Modbus device to gather data measurements and the data comes through from OPC tags for ~10 seconds (data is updating), but then it stops.
The logs show this message: ReadHoldingRegistersRequest , Request failed. FailureType==DISCONNECTED
I’ve been playing around with my tag groups and their common Rate (~10,000) and custom opcRate (~10,000). Should I be using both of these rates with the same value? I have been using two different values.
Is this the same case as (Modbus TCP Request Failed)? Could you direct me to the fixes that were mentioned here ([bug-14313]Direct Tag Group running on Leased/Driven rate)?
Detailed message below:
java.lang.Exception: RequestCycle stopped.
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle.shutdown(BasicRequestCycle.java:281)
at com.inductiveautomation.xopc.driver.api.AbstractDriver.createNewRequestCycle(AbstractDriver.java:763)
at com.inductiveautomation.xopc.driver.api.AbstractDriver.notifyDisconnectDone(AbstractDriver.java:722)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.notifyDisconnectDone(AbstractIODelegatingDriver.java:71)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.disconnect(AbstractIODelegatingDriver.java:43)
at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.reconnect(AbstractIODelegatingDriver.java:93)
at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver.access$000(AbstractModbusDriver.java:97)
at com.inductiveautomation.xopc.drivers.modbus2.AbstractModbusDriver$2.notifyCommunicationTimeout(AbstractModbusDriver.java:138)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusRequest.fail(AbstractModbusRequest.java:169)
at com.inductiveautomation.xopc.drivers.modbus2.requests.AbstractModbusReadRequest.fail(AbstractModbusReadRequest.java:121)
at com.inductiveautomation.xopc.driver.api.requests.TimedRequest.fail(TimedRequest.java:44)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.failRequests(BasicRequestCycle.java:374)
at com.inductiveautomation.xopc.driver.api.BasicRequestCycle$TimeoutDaemon.run(BasicRequestCycle.java:329)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
